ᐅ IKEA Besta – What Common Mistakes Should Beginners Avoid When Assembling?
Created on: 23 Dec 2022 08:42
Soniba
Soniba
23 Dec 2022 08:42
Hello everyone, I am currently planning to assemble an IKEA Besta system and have been studying the assembly instructions thoroughly. Since I am a beginner, I want to do it right from the start and avoid common mistakes that could make the entire cabinet unstable or faulty. What typical errors do beginners often make when assembling the IKEA Besta system? What should one pay close attention to in order to ensure that everything is stable after assembly, the drill holes align correctly, and no consequential damage occurs? Are there any special tips or critical areas where you need to be especially careful? Thanks for your experiences and advice!
anfeteo
23 Dec 2022 09:17
That’s a great question, Soniba! When assembling IKEA Besta, there are some common mistakes that beginners often make. Here is a structured overview:
- Preparation: Before starting, make sure to count all the parts and screws and have the tools ready. Missing parts can cause significant problems later on.
- Aligning drill holes correctly: The manufacturing is usually precise, but if you drill the wood too deeply before screwing or insert screws at an angle, you risk chipped edges or unstable connections.
- Installing the back panel properly: Often underestimated, the back panel greatly stabilizes the entire system. Missing or poorly secured back panels quickly lead to wobbling.
- Following the sequence: Always follow the instructions step by step and initially assemble the individual modules loosely. Only tighten everything firmly at the end to avoid tension.
In summary: work slowly and carefully, ensure screws are positioned firmly and straight, and don’t underestimate the back panels. Could you say whether you are building mainly a large shelving unit or connecting individual elements? That influences some of the advice a bit.
BARSAN
23 Dec 2022 09:43
The most common mistakes are uneven installation due to incorrect alignment, drilling holes too deep or not drilling at all, and not securing the back panel properly. Just work slowly, and it will turn out fine.
FeAndreas1
23 Dec 2022 18:29
I like to go into detail because careful planning is especially worthwhile for long-lasting stability with IKEA systems like Besta. Important points are:
- Do not overtighten screws: The steel sheet connectors (metal fasteners) hold the units together. If tightened too much, the chipboard around the connection can tear. Be cautious here, and having a feel for torque is very helpful.
- Align and secure the back panel precisely: It is often attached with small nails that can easily slip. A useful tip is to cut the back panel to the exact size (if needed) and carefully tap small nails nationwide with a hammer. This significantly increases stability.
- Hole patterns: IKEA’s standard hole rows are cleverly designed, but beginners often confuse the sides (left is not always left as per instructions). Especially when assembling multiple units, it’s worth double-checking before screwing.
- Consider load distribution: Heavy items should always be placed at the bottom. Shelves can bow over time if overloaded.
- Casters or feet? My recommendation is to choose fixed feet for more stable support.
Finally, maybe a simple question: Do you use a standard screwdriver or a cordless drill, and how much experience do you have with furniture assembly? This can help tailor the advice further.
Soniba
24 Dec 2022 07:58
anfeteo schrieb:
Preparation: Before starting, make sure to count all parts and screws and have the tools ready.
This is an important point for me, thanks! I have the workshop set from IKEA and a small cordless drill, that should work well.
FeAndreas1 schrieb:
Don’t overtighten screws: The metal connectors hold the units together; if tightened too much, the particleboard around the connection will crack.
That is a concern of mine, I once had an inexpensive piece of furniture where exactly that happened.
I’m building a larger shelf, about 180cm by 80cm (71 inches by 31 inches), using several base modules that I’m connecting together.
I have little experience with load distribution, so it’s great that you mention it—I will put heavy items at the bottom.
Does anyone have advice on preventing misunderstandings regarding the hole patterns or tips for precise alignment? I want to avoid unnecessary rework.
anfeteo
25 Dec 2022 11:03
Soniba schrieb:
Does anyone have recommendations about misunderstandings regarding the hole rows or tips for accurate alignment?
Gladly! There are a few proven tricks when it comes to the hole rows:
- Use a spirit level and preferably a small protractor or angle gauge when screwing parts together. This helps keep the components on the same plane.
- When connecting the individual modules, initially tighten the screws only by hand. This allows for adjustments if something is misaligned.
- If you want to connect several modules, lay them out side by side on the floor and check the alignment with a long straight edge or a smooth-edged board.
- Always check whether the drill holes line up precisely before fully tightening the screws.
- Sometimes it helps to press the panels together with slight pressure while inserting the connection screws, so they close neatly without gaps.
The most important thing: be patient and work step by step. A small mistake at the beginning often gets amplified during assembly.
