ᐅ Using IKEA BESTA: How Can I Neatly Route Cables Through the Furniture?
Created on: 28 Nov 2018 18:23
Mijodu
Mijodu
28 Nov 2018 18:23
Hello everyone, I am planning to assemble an IKEA Besta unit as a media cabinet and am facing the challenge of routing all power, HDMI, and network cables as neatly and invisibly as possible through the furniture. The unit has back panels made of wood boards, some with small cutouts for cables, but I am unsure of the best way to install cable ducts or routing systems without compromising the stability of the unit or disturbing the appearance with partially visible cables, especially at night. Are there proven methods or specific accessories for cable management in a Besta unit? I would appreciate any tips, including recommendations for tools, good cable grommets, or clever tricks if you have experience with this. Thanks in advance!
sarGabriel
28 Nov 2018 18:44
The easiest way is to cut out the back panel where cables need to pass through and then install flexible plastic cable ducts or cable grommets. Cable ties and hook-and-loop straps also help to keep everything neatly organized and routed.
Ixvin
28 Nov 2018 19:07
Hello! The topic of cable routing with BESTA is popular, and there are several solutions you can try. First of all, I would recommend starting your planning by precisely noting where each device will be placed and where the cables need to run. The back panels on BESTA are relatively thin, often only 3 mm (0.12 inches), so you should avoid making cutouts too large in order to maintain stability.
A practical tip is to drill small holes (for example, using hole saws or routers) in the furniture base or side panels to guide cables through. Using appropriate cable grommets (plastic rings or rubber sleeves) allows you to work neatly both visually and mechanically, without squeezing the cables.
For the actual cable management, you can use internal cable ducts, or—if space is limited—bundle cables together with Velcro straps or cable ties and attach them to the inside walls. If you use power strips with long cables, it’s worth routing the cables along the underside of the furniture base.
Even better is to size the cables in advance so they are not tangled or excessively long, but as direct as possible from the device. If you like, I can also provide tips on special tools.
Mijodu
29 Nov 2018 08:12
Ixvin schrieb:
The back panels in BESTA are relatively thin, often only 3 mm (0.12 inches), so you should avoid making cutouts too large to prevent compromising stability.
This is an important point for me because I had assumed I could make larger cutouts. Is there a way to add or install something like "cable ducts" that reinforce the back panel or at least help maintain stability? I would prefer to avoid the furniture becoming wobbly or developing cracks later on.
Ixvin schrieb:
For cable management itself, you can use cable ducts inside
Could you maybe give an example of how this is practically implemented with a BESTA unit? Are there specific cable ducts available that are not too bulky and can be well concealed within the furniture?
I want to keep the outside as unobtrusive as possible, but have everything neat inside. Thanks!
GUSTAVO56
29 Nov 2018 09:47
I’m happy to provide you with some detailed tips for neat cable management with BESTA.
The back panel is actually a critical point because it is thin and serves as a stabilizing element. Instead of cutting out large sections of the back panel, I recommend the following approach:
- Use smaller, round or oval cutouts only where cables really need to pass through (maximum diameter of 3–4 cm (1–1.5 inches)).
- Insert rubber grommets or plastic cable glands into the cutout holes to protect the cables and prevent wear on the edges.
- Inside, you can install plastic cable ducts, which can be fixed to the side or bottom walls with small screws or double-sided tape. These ducts are available in a flat design just a few millimeters high (a few millimeters high), so they don’t take up much space.
- One trick is to mount multiple ducts in parallel for different cable sets to keep everything organized.
- If the furniture is meant to look especially tidy, cable spirals can be used; these not only look neat but also offer good protection for the cables.
Tools you might need:
- Hole saw (e.g., 40 mm (1.5 inches)) for back panel cutouts
- Fine file and sandpaper to smooth the edges
- Side cutters for cable ties
If you want to hide power outlets or power strips inside the furniture, you should plan the cable routing in advance and possibly install cable ducts under the furniture base.
I’m also interested in how much technology you want to hide inside, so I can better advise you regarding sizes and types of cables.
Mijodu
29 Nov 2018 11:03
GUSTAVO56 schrieb:
I’m curious about how much technology you plan to hide inside so I can better advise you on the sizes and types of cables.
That’s a very good question. I plan to store my gaming console, a small AV receiver, a cable box, and a router inside the BESTA unit. This means power cords, HDMI cables, Ethernet cables, and possibly USB or audio cables. In total, I estimate around 6-8 cables, some thicker power adapters and some thinner signal cables. It’s important that the Wi-Fi signal is not affected, so I want to avoid metal parts that could cause interference.
I like your suggestion about running separate cable channels in parallel, but I do see a space constraint in the depth of the furniture (about 40 cm (16 inches)). Are there any recommended cable channels that remain flat and can be easily adapted? Thanks in advance!
