ᐅ IKEA BESTA – How Can I Replace the Hinges Myself?
Created on: 27 Apr 2020 17:23
rhettma
rhettma
27 Apr 2020 17:23
Hello everyone, I have an IKEA BESTÅ sideboard, and the hinges on some of the doors no longer close properly or have become loose. I want to replace the hinges myself but am unsure about the best way to do this, as there seem to be different types. Could someone please explain step by step how to remove and replace the hinges on an IKEA BESTÅ? What tools do I ideally need, and are there any particular things I should pay attention to so that the doors are properly aligned afterward? Thanks in advance for your help!
gadalu
27 Apr 2020 18:09
Basically, replacing the hinges on the IKEA BESTÅ is quite straightforward since the hinges are modular and can be removed with just a few simple steps. You mainly need a Phillips screwdriver (PH2) and possibly a flathead screwdriver for adjustable parts.
Procedure:
- Fully open the cabinet door.
- The hinge is usually attached to the door with two screws; loosen these.
- Then release the hinge from the cabinet frame by pressing out the mounting clip (usually a simple plastic clip).
- Simply click the new hinge into the clip and attach it to the door panel with screws.
- Finally, slightly adjust the screws on the cabinet frame mounting to align the door (usually adjustable sideways, vertically, and in depth).
Note: Before purchasing, make sure the new hinges are designed for the BESTÅ system and have the same mounting method (e.g., cup hinges with a 35mm (1.4 inch) drill hole).
With this, the doors should close properly again after the replacement.
enrique7
27 Apr 2020 20:34
gadalu schrieb:
Procedure:
- Then release the hinge from the cabinet body by pressing out the retaining clip (usually a simple plastic clip).
- Simply click the new hinge into the clip and secure it to the door panel with screws.
Overall a good overview, but I would add that you should be careful when removing the old hinges because some Bestå modules have a glued back panel that shouldn’t be pulled too hard. Also, are there any recommendations on whether to use original replacement parts from IKEA, or do compatible hinges from third-party suppliers work just as well? For someone handling this for the first time, that would be useful information.
tolokau
28 Apr 2020 08:41
I would like to add a brief guide for replacing the hinges on the IKEA BESTÅ.
1. Preparation:
- Gather tools: PH2 Phillips screwdriver, possibly a small flathead screwdriver.
- Arrange the workspace so that the doors can open freely and be placed down safely.
- If available, have replacement hinges ready (preferably the original ones).
2. Removal:
- Fully open the doors.
- Loosen the screws of the hinge on the door.
- Carefully release the attachment on the cabinet by pressing or pulling the clip.
- Lay the door down carefully.
3. Installation:
- Click the new hinge into the attachment on the cabinet.
- Secure the hinge to the door with the screws.
4. Adjustment:
- The adjustment screws on the hinge allow you to align the door in three directions: vertical, horizontal, and depth.
- Ideally, adjust so the door closes flush and has no large gaps around the frame.
Common mistakes during self-installation include overtightening the screws or neglecting adjustment, so please follow these steps carefully.
If anyone needs exact screw types or measurement details, I can provide those as well.
WARREN
28 Apr 2020 09:15
Lift the door, loosen the screws on the hinge, remove the hinge, attach the new hinge, insert the screws, then adjust.
Tool: Phillips screwdriver.
Original replacement parts are usually the most reliable.
