ᐅ Ikea Besta: How can I install a child safety lock on the doors?
Created on: 23 Sep 2022 10:12
Timurson
Timurson
23 Sep 2022 10:12
Hello everyone, I hope someone can help me with my question about child safety locks for Ikea Besta cabinets.
I have just assembled a Besta system with several doors and am looking for a reliable child safety lock that is easy to install without damaging the doors or the material – ideally something that can also be removed without leaving any residue. It is important to me that the lock prevents small children from opening the doors but remains easy for adults to operate.
Does anyone have experience with which products work best – for example, magnetic locks, mechanical latches, or special fasteners? How do I properly install these on the Besta doors, which are often made of coated particleboard? Are there any special tips for installation to ensure the child safety lock is really secure and discreet?
I look forward to your recommendations and detailed advice on installation! Thanks in advance.
emmett
23 Sep 2022 10:46
Simple clip-on or adhesive locks that attach directly to the cabinet door and frame are suitable for Ikea Besta.
- It is important to clean and dry the surface thoroughly beforehand.
- Installation is usually done with screws or adhesive strips, depending on the model.
- Magnetic locks are typically installed inside the cabinet and opened with a separate key.
If you want to avoid damaging the material, I recommend adhesive options that can be removed without leaving any marks.
Tevin
23 Sep 2022 14:03
Hello Timurson, I’m happy to help.
For Ikea Besta, I recommend child safety locks designed specifically for furniture doors with smooth surfaces. Most of these use either an adhesive or screw mounting system. Important points for installation:
- Clean the surfaces thoroughly before installation (e.g., with isopropanol) to ensure the adhesive sticks well.
- With magnetic locks, an invisible latch is installed inside, blocking the door. The door can then be opened using a magnetic key.
- Mechanical latches are easier to use but should be mounted on the door edges—drill pilot holes carefully if needed.
- Check the version of the Besta system, as some door types are thinner or have different edges, which may affect installation.
Generally, installation without drilling is possible if using adhesive locks. However, you must ensure good adhesion, or the lock may come off under stress. User reviews of different brands can be helpful in making a decision.
If you have further questions about the mounting method, I’m glad to assist.
Fitigu
24 Sep 2022 09:17
For additional information:
Tevin schrieb:
For Ikea Besta, I recommend child safety locks that are specifically designed for furniture doors with smooth surfaces.
That is correct. In this context, I would suggest the following:
- Use high-quality adhesive strips, preferably 3M Command Strips, which are commonly used for child safety locks. They provide strong hold, remove cleanly without residue, and work well on coated surfaces like those of Besta.
- For magnetic locks, I recommend installing them inside the cabinet to avoid affecting the overall design.
- Make sure to carefully follow the instructions of the child safety products, especially the drying times after cleaning the surfaces, to maximize adhesion.
- An optional alternative is hinge locks, which can be mounted on the hinges and remain hidden from view.
Before final installation, a trial fit can be useful to ensure proper functionality and avoid incorrect mounting.
These tips help reduce potential damage to the furniture and ensure a secure child safety solution.
