ᐅ IKEA BESTA DIY – How can I improve the opening mechanisms?
Created on: 9 Sep 2020 07:35
mickkla
mickkla
9 Sep 2020 07:35
I am currently exploring the topic “IKEA Besta DIY – how can I improve opening mechanisms?” and I’m looking forward to your experiences and ideas.
Background: The BESTA series is quite versatile, but I find the standard hinges and push-to-open mechanisms on the doors and flaps somewhat unsatisfactory. They often feel a bit stiff or don’t always seem durable, especially with frequent use.
I’m particularly interested in how to optimize the opening mechanism so that it operates more smoothly, quietly, and, above all, reliably—without having to resort to expensive external systems. Are there any proven tricks, modified hinges, or alternative solutions that you have used in your BESTA projects?
I look forward to your practical tips, experiences, and any warnings about potential pitfalls to avoid.
WARREN
9 Sep 2020 08:02
I would recommend replacing push-to-open hinges with soft-close hinges. They are more durable and ensure a noiseless closing. For smoother operation, just oil the hinges. That’s it.
KUDAISY
9 Sep 2020 10:14
here is an overview with practical tips on opening mechanisms for the IKEA BESTA series:
1. Replace hinges: Swap standard hinges for high-quality soft-close or clip-on models. Advantage: quiet and smooth closing, better durability.
2. Magnetic opening mechanisms: Instead of push-to-open, magnetic catches with light spring returns are recommended. These are more robust and require less maintenance.
3. Spring-assisted door openers: There are special gas springs for smaller flaps that make opening easier and protect against wear.
4. Avoid installation errors: Make sure to precisely adjust the hinges during installation, otherwise the mechanisms become stiff or misaligned.
5. Lubricants: Use specifically suitable Teflon or silicone spray to effectively reduce friction and wear.
Summary: To improve the opening mechanism, it is best to invest in soft-closing hinges or magnetic systems, combined with careful installation and lubrication.
Common mistakes: Neglecting adjustment leads to unnecessary stress.
Natan
9 Sep 2020 12:47
WARREN schrieb:
I would recommend replacing push-to-open with soft-close hinges.
That’s basically a good recommendation, but isn’t it a paradigm shift? Push-to-open can allow convenient hands-free operation, whereas soft-close focuses more on gentle closing.
I’m also interested to know if anyone has tested the interaction between soft-close hinges and the original Besta fronts – do they all fit mechanically without extra effort?
Furthermore, I wonder how durable such mechanisms are compared to simple push-open fittings, especially under everyday use.
In principle, I think it makes sense not only to optimize functionality but also to question the sustainability of the materials used. Does anyone use long-lasting alternative products to the IKEA standard?
hauklo
10 Sep 2020 09:21
For improving opening mechanisms in IKEA BESTA units, here are some precise recommendations:
- Soft-close hinges from third-party manufacturers are often better sized and feature more durable spring and damping systems.
- If the front panel wobbles or does not align perfectly, adjustable mounting plates are recommended, as they allow for precise alignment.
- For push-to-open mechanisms, it is advisable to choose high-quality spring systems, since cheaper versions often wear out quickly.
- Installing damped drawer slides can further enhance the opening experience.
- Lubricants: Use silicone-free oil-based lubricants suitable for plastics, as some lubricants can damage plastic components.
- Mechanical stress from door weight is relatively low; most issues result from poor adjustment and low-quality components.
Conclusion: Improvements can be achieved by retrofitting high-quality parts, precise adjustments, and avoiding inexpensive replacement parts without proven long-term performance.
JONKO
11 Sep 2020 18:06
Natan schrieb:
I’d also like to know if anyone has tested the interaction of soft-close hinges with the original Besta fronts – do they all fit mechanically without extra adjustments?
I tried exactly that a few weeks ago. The third-party soft-close hinges fit without major modifications, but you need to align the drill holes precisely and sometimes carefully adjust the fronts to ensure the gap is even.
hauklo schrieb:
For push-to-open mechanisms, it’s important to choose high-quality springs, as cheaper versions tend to wear out quickly.
I can confirm that. When I expanded my Besta furniture, I initially installed cheap push-to-open mechanisms – after a few months, the actuation point broke. Currently, I use magnetic openers, which work very reliably and quietly.
In general, it’s important to me that the mechanism not only works well but remains enjoyable to use over time without annoying defects. I can recommend the combination of soft-close hinges and magnetic openers.
