ᐅ IKEA BESTA Assembly: Key Tips for Building a Stable Piece of Furniture
Created on: 26 Sep 2022 14:37
Betane
Betane
26 Sep 2022 14:37
I am currently planning to assemble an IKEA Besta sideboard and want to create a particularly sturdy piece of furniture. Therefore, I am interested in any tips and tricks you have for maximizing the stability of the BESTA system during assembly.
Specifically, I would appreciate advice on:
- handling screws and fittings (e.g., tightening torque, assembly sequence)
- preparing walls or floors (possible fixing or reinforcement)
- combining multiple units (e.g., connecting several BESTA modules)
- useful reinforcements that can be added additionally
I want to avoid the furniture wobbling or warping after a short time – so experience with assembly and stabilization is very welcome.
Thanks for your suggestions!
glapu
26 Sep 2022 15:08
With the BESTA, tighten all screws enough so they are secure but not overtightened.
If possible, anchor the furniture to the wall. This makes the biggest difference in stability.
Ethan
26 Sep 2022 16:22
Hello Betane,
your concern about making the BESTA construction as stable and durable as possible is completely justified. The BESTA system is versatile, but achieving good stability really depends on the correct assembly.
First, I would recommend always installing all screws and connectors with a cordless drill without a hammer function. This helps prevent over-tightening, which can damage the threads. A secure but not overly rigid connection provides support without weakening the wood.
The installation of the back panel also plays an important role. IKEA back panels in BESTA are relatively thin and can be reinforced at stability points by, for example, attaching a thin plywood panel. This prevents warping and increases rigidity.
Regarding connecting multiple modules: use the supplied fasteners very carefully; often there are small metal brackets or special hinges included. Always position these exactly aligned to avoid the furniture twisting.
An additional option is to install corner brackets inside, either under the top panel or at the base. These can improve load-bearing capacity, especially for longer sides.
Finally, I strongly recommend securing the furniture to the wall – especially if the piece is tall or long, as this prevents tipping and significantly enhances stability and safety.
I hope these detailed tips help you!
Joshbe
27 Sep 2022 09:41
Ethan schrieb:
An important aspect is also the installation of the back panel. IKEA back panels for BESTA are relatively thin and can be reinforced at critical stability points by adding, for example, a thin plywood sheet. This prevents warping and provides greater rigidity.
That is a very good point. Additionally, I recommend paying close attention to alignment during assembly – the furniture should be placed on a level surface to avoid pressure marks or unevenness.
The order of assembly is also important to ensure optimal stability:
- First, assemble the individual carcass parts
- Install and secure the back panels (possibly reinforce them)
- Connect and align the modules
- Attach wall fixings
It is also important to decide whether the installed shelves will be heavily loaded. For heavy loads, additional support braces or avoiding excessively wide shelves is advisable.
Furthermore, I recommend always following the assembly instructions carefully, with a focus on precise horizontal alignment – even small inaccuracies can cause wobbling later on.
JAFUHAU
27 Sep 2022 18:56
I really appreciate that you’re discussing the BESTA assembly process in such detail. At first, I had little patience with the individual steps and the stability – the furniture wobbled for me initially, and I was quite frustrated.
Over time, I learned that it’s not just about tightening the screws properly but also about the surroundings: our laminate floor was slightly uneven, which also caused minor rocking. Adding small felt pads under the furniture legs helped a lot.
Additionally, I can confirm that securing the furniture to the wall is absolutely essential, not only for safety but also for stability. At first, I left the furniture freestanding, which definitely wasn’t ideal.
Another factor that might matter, especially if you have children or pets, is that frequent opening of the doors can affect the screw connections. It’s worth occasionally re-tightening them.
I hope these useful tips help you build a solid piece of furniture. If you like, feel free to share how it goes for you!
