ᐅ How to Securely Attach an IKEA Malm Nightstand – Step-by-Step Guide?
Created on: 4 Jul 2021 19:23
Teoel40
Teoel40
4 Jul 2021 19:23
I recently purchased the IKEA Malm nightstand and am now facing the challenge of securing it firmly and safely. My specific question is: How can I mount and fix the IKEA Malm nightstand to the wall or the bed in a way that it is completely stable, without any wobbling or the risk of tipping or sliding over time? I am particularly interested in the best methods, suitable tools and materials, as well as tips on important points to consider when fastening it. Perhaps someone has experience with the original instructions or alternative, proven techniques?
I mainly use the nightstand for my bedside lamp and a few books and want to avoid instability or damage caused by insufficient fastening. Any guidance or recommendations, including assessments of durability, are greatly appreciated. Thanks in advance!
Juan31
4 Jul 2021 20:37
Teoel40 schrieb:
How can I assemble the IKEA Malm nightstand and secure it to the wall (or bed) so that it stands completely stable without wobbling or eventually tipping or slipping?
The best method for maximum stability is to attach it to the wall using metal brackets or furniture anchors. For this, you will need appropriate wall plugs and screws, matched to the type of wall (e.g., concrete, drywall).
Assembly steps:
1. Position the nightstand where you want it.
2. Check the level and height using a spirit level.
3. Drill holes in the wall with the correct diameter.
4. Insert the wall plugs and fasten the brackets to both the nightstand and the wall.
This prevents tipping and ensures long-lasting stability. Tools needed: cordless drill, drill, spirit level.
If mounting to the bed, special clamp fittings are possible but generally less stable.
Question: What type of wall do you have? This affects the choice of wall plugs.
rigau
5 Jul 2021 08:46
Juan31 schrieb:
Clarification: What type of wall do you have?
Getting straight to the point: Without wall mounting, the Malm nightstand quickly becomes unstable under load. It’s best to always secure it with at least two screws using appropriate anchors. Drywall requires hollow wall anchors, while concrete needs universal anchors.
pikin
5 Jul 2021 11:52
Teoel40 schrieb:
Tips on what to watch out for when fixing
To add, here are some things you should consider:
- Always use a spirit level to ensure the bedside table is perfectly straight.
- Check the load-bearing capacity of your wall, especially if you plan to place heavy items on the bedside table.
- Avoid cheap wall anchors; opt for branded products to ensure optimal holding strength.
- Do not fix only at the “top” or “bottom” to prevent tilting; use at least two fixing points.
- When mounting to wooden beams or a timber batten wall, wood screws can be used instead of wall anchors.
If you like, I can prepare a list of recommended fixing materials for you.
