I plan to use some IKEA Malm furniture, especially dressers and nightstands, as long-lasting as possible. Although these pieces are affordable, I am sometimes concerned about their durability and stability over time. I am particularly interested in how to significantly extend the lifespan of this furniture – both in terms of maintenance and structural improvements or preventive measures against wear.
Are there any special tips for the material (particleboard with laminate finish?), for fastening, or for protection against moisture and load? Does anyone have practical experience with how to prevent warping or damage from daily use?
I would be very grateful for any advice, including repair options if something becomes loose or breaks. Thanks in advance!
Hello branda,
I think your concern is very important because the MDF or particleboard constructions of many IKEA furniture pieces are practical but not necessarily designed to last for decades. I can offer some detailed advice regarding durability:
Moisture is indeed one of the biggest enemies of the Malm series, as the panels are usually covered with a thin foil that somewhat protects the edges. However, moisture can still penetrate through edges or screw holes and cause swelling.
My tip: Make sure the furniture is not placed near radiators or in consistently damp rooms. If you are using Malm dressers that are open at the back, applying an internal moisture barrier (such as foil or special coatings) can help.
Regarding screws: IKEA provides the necessary fasteners with the furniture, but it’s worth replacing them with high-quality screws of a smaller diameter. Regularly tightening the screws is recommended.
Also, adding metal corner brackets inside the carcasses can improve stability, especially under frequent use loads.
If you want to protect the surfaces, I recommend using appropriate furniture waxes or special felt pads under pieces that might cause movement or friction.
Could you briefly share which room the furniture is in and how heavily it is used? That would help provide better recommendations.
Alberto5123 Apr 2022 07:42Hello branda,
I want to encourage you: I bought my Malm dressers 7 years ago, and despite some minor flaws, they are still working very well.
I have experienced that too, so I only clean them with a slightly damp cloth and also make sure there is good air circulation in the room. Sometimes I worry about the small corners and edges, but a piece of furniture like this almost feels like part of the home to me :-)
I'm curious—how do you deal with scratches or small damages? I have sometimes wondered if these can be repaired with wood filler or special repair kits.
Marlenepa23 Apr 2022 15:03Hello everyone,
I really like the discussion here because I have similar questions and would like to add a few basic points.
Malm mainly uses coated particleboards, which need to be properly maintained. It is important not to use harsh cleaning agents, as they can damage the film surface. Instead, water with mild dish soap and a soft cloth is gentle enough.
When assembling, it’s also advisable to tighten all screws again after about one week, as the components often settle slightly. For extra stability, I installed small metal brackets inside some of my furniture pieces from the same series. This provides more durability, especially when drawers are frequently used.
Regarding small repairs: there are special wax sticks or repair kits for visible areas that can be applied carefully. For hidden spots, some wood glue can help. It’s important to properly maintain the surface afterwards.
If anyone is interested, I’m happy to offer recommendations for specific products! 🙂
Oh, and one more tip: you can line the inside walls of drawers with anti-slip mats to protect the bottoms and prevent excessive movement.
I hope this helps a bit!
Alberto51 schrieb:
I’m curious – how do you deal with scratches or minor damage?
