ᐅ What is the best way to repair paint damage on Malm furniture?
Created on: 3 Jul 2021 19:37
BugovinHello everyone, I have noticed some paint damage on my Malm furniture from Ikea, which I would like to repair as discreetly as possible. The damage mainly involves small scratches and chipped areas where the original paint is visibly damaged. My question is: what is the best way to apply paint touch-ups on Malm furniture to achieve an even finish? I am looking for a method that is easy to carry out and does not result in a noticeable shine or color differences after the repair. Which products and techniques work best for this? Thank you very much for your advice!
Hello, here is a brief guide for repairing paint damage on Malm furniture: 1. Preparation: Clean the damaged area thoroughly with a lint-free cloth and some isopropanol to remove grease and dirt. 2. Sanding: Lightly sand the damaged area and its immediate surroundings using fine 400-grit sandpaper to open up the surface for the paint. 3. Color matching: Find a suitable paint pen or furniture touch-up pen that closely matches the white shade of Malm. Ikea often uses a smooth, glossy white, so look for a high-gloss version. 4. Application: Apply the paint thinly in several layers, allowing each layer to dry well. It is important not to apply too thickly, as this can make the area look unnatural. 5. Finishing: Once dry, you can gently scuff the spot with very fine sandpaper (e.g., 800-1000 grit) to blend the transition. 6. Optional: If the gloss level is off, you can apply a special clear coat for furniture. Make sure it matches the surface finish (matte or glossy). Common mistakes include applying paint too thickly or choosing the wrong color tone. Good luck!
LOJOPAR schrieb:
Looking for a suitable touch-up pen or furniture correction marker that matches the white shade of Malm as closely as possible. Can anyone recommend a specific brand or product? I found some markers at hardware stores but am unsure if they really match Ikea Malm well. Are there any special furniture repair kits that might be suitable for this?
REOHEINRIC4 Jul 2021 10:11I can recommend the products from “Effekt Lacquer Pen,” especially the white shades, which work well for IKEA furniture. These pens are available in many hardware stores and online. It is important to test the color on an inconspicuous area before application. For larger damages, repair kits with primer, color paint, and clear coat are worth considering, as they provide a long-lasting solution. When working on Malm furniture, pay attention to the glossy surface, otherwise the repair spots will be noticeable. Sometimes it helps to remove the furniture piece before repairing and work on it in a stationary position.
I understand well how frustrating paint damage on Malm furniture can be. 🙂 Especially on visible white surfaces, it becomes noticeable quickly. What worked well for me was applying the paint slowly with a fine brush instead of using paint markers. This way, you can better control the amount and adjust the color tone more precisely. Another tip: patience is important, as multiple thin layers often yield the best result. If you’re unsure, don’t worry—this takes a bit of practice but can be learned easily. Good luck, and don’t get discouraged!
