ᐅ IKEA Malm Furniture Surface Scratched – Repair Kits?
Created on: 26 Nov 2015 18:22
FABRICES61
FABRICES61
26 Nov 2015 18:22
I have a problem with my IKEA Malm dresser: the surface has some noticeable scratches that really affect the overall appearance. Since the furniture’s surface coating is relatively thin, I don’t want to repaint or replace it right away. Instead, I’m looking for practical and sustainable repair solutions.
I’m interested to know if anyone has experience with special repair kits for Malm furniture surfaces – for example, wax sticks, repair kits, or other products that can actually hide or even remove visible scratches.
Which kits are recommended in terms of quality? And what really works well in everyday use without needing frequent touch-ups afterward? Any tips on color matching or surface preparation would also be very helpful.
Thanks in advance for any advice, including personal experiences or recommendations from specialists.
Best regards!
RATAR
26 Nov 2015 18:47
Hello Fabrices61,
thank you for your detailed question – I completely understand how frustrating those scratches on the Malm surface can be. I have experienced this myself and spent quite a while searching for a somewhat suitable repair kit.
I think it’s great that you’re looking for practical solutions, as simply repainting over can often result in an uneven finish. I found that a wax repair stick from a hardware store helped, although the color didn’t match the furniture perfectly; however, this can be somewhat balanced out with careful blending.
Sometimes fine sandpaper followed by special furniture polishing wax can also help – this reduces the appearance of small scratches. It’s important to thoroughly clean the surface beforehand.
I would also appreciate it if others could share which repair kits hold up well or if there are professional products that IKEA themselves recommend for Malm.
V
van_pe
26 Nov 2015 19:02
Wax sticks from „Möbel Repair“ often work well. The color shade is crucial, so it’s best to test them.
nesau3
26 Nov 2015 19:17
This is such a great topic! 🙂
I recently had similar scratches on my Malm nightstand.
My tip: Try a repair wax stick (available on Amazon). It’s inexpensive and surprisingly effective!!
Even better: Gently polish afterwards with a microfiber cloth – it almost looks like new again!
Don’t worry, these kinds of mishaps can really be fixed 😉
LAYNE
26 Nov 2015 19:39
Hi,
A small tip from me: if the scratches are not too deep, color-matching felt-tip pens also work well for touch-ups.
I tried this on another piece of furniture – it works as long as you don’t expect a perfect result ;-)
Luckily, Malm items are quite affordable, so it’s often worth doing a bit of DIY.
V
valerie-tr
26 Nov 2015 20:15
Regarding FABRICES61’s question, I would like to add some details:
The Malm series is made with melamine resin-coated particleboard, meaning the surface is very thin and hard but also sensitive to scratches, as the coating cannot be refinished like solid wood.
A repair kit should ideally include the following components:
1. Cleaning solution without harsh solvents (e.g., isopropanol) for pre-treatment
2. Wax sticks matched to the furniture color, containing wax-based fillers with pigments
3. A fine polishing cloth or abrasive pad for even blending
Using overly aggressive products can quickly cause dull spots or an uneven surface.
For preparation, I would gently clean the affected area, as dust and grease prevent optimal wax adhesion. Then apply the wax stick locally, remove any excess wax, and work it in with a cloth.
Regarding color matching: IKEA usually uses light, white, or birch-like tones for Malm, which often makes finding suitable wax colors difficult. However, there are kits that include several shades, allowing for mixing.
I would also like to ask: Are these mostly fine scratches or really deep grooves? This greatly influences the approach.
