ᐅ How to successfully assemble Ikea Hemnes furniture without the instruction manual?
Created on: 24 Sep 2021 08:27
V
Vinme
Hello everyone, I am currently facing the challenge of assembling an Ikea Hemnes shelf unit completely without the included instruction manual. Since I don’t have the manual, I’m looking for tips and experiences on how to best identify the individual parts and assemble them correctly without relying on the usual step-by-step guide. I would really appreciate any advice on the process, tools you used, and common pitfalls to watch out for. What strategies have you applied to ensure a smooth assembly? Are there perhaps hidden markings on the wooden parts or screws that indicate a particular order? For my planning, it would also be helpful to know roughly how much time I should expect for assembly without the instructions. Thank you in advance for your input!
PLOMA
24 Sep 2021 17:31
Vinme schrieb:
How can I tell whether they are meant to be installed at the front or back of the furniture? And how important is it to maintain the correct orientation of the boards?
Adding to what Dwight49 and ronti said: also pay attention to small glue residues, which can sometimes be found on the edges and corners—for example, on the back side of drawer bottoms.
The grain pattern is not only important visually, but the board’s stability is also supported by its orientation. Usually, the edges are slightly rounded on the front side to provide a more comfortable feel.
Regarding the drawers: the runners have a marked installation direction—often one side is marked with an arrow. If you can’t identify this, try installing them so they slide smoothly without sticking. Any rubber or plastic parts should be placed at the contact points to ensure quiet operation.
If you’re still unsure which parts to use for the drawers, feel free to describe their shape and dimensions in more detail.
FRANCISCOP
25 Sep 2021 08:17
Continuation on the topic of time required: Based on experience, assembling a Hemnes shelf unit without instructions takes about 3–4 hours, depending on DIY skills and available tools. Aligning and correctly installing the drawers in particular requires time.
A structured approach is helpful: start with the main frame, then the drawers, and finally the back panel. Try to tighten all screws only by hand at first, so mistakes can be corrected easily.
V
Vinme
25 Sep 2021 09:42
FRANCISCOP schrieb:
Try to initially tighten all screws only by hand to be able to quickly correct assembly errors.
That perfectly fits my assembly approach; I will take that as an excellent tip.
Today, I will systematically start the inventory of the components again, especially to better identify the markings.
Thanks to everyone so far for the valuable advice; it already gives me a solid foundation to tackle the challenge.
