ᐅ How sturdy are IKEA PLATSA shelves and boards for everyday use?
Created on: 9 Aug 2021 14:03
NicolisHello everyone,
I am planning to build a new shelving unit in my apartment using the IKEA Platsa system. I am particularly interested in how strong the Platsa shelves and units are in everyday use. An assessment of their load capacity and stability under typical conditions—such as storing books, kitchen utensils, or somewhat heavier everyday items—would be very helpful.
I have read that the shelves are made of particleboard with a foil coating, which probably makes them less durable than solid wood. Are there any experiences that provide insight into how long the shelves last without sagging or damage? And how do they compare in terms of robustness to other IKEA shelving systems, like Kallax?
It would also be important to know if certain assembly options—such as shelves with or without a center support—affect stability. I would appreciate reports from daily use or technical knowledge on this.
Thank you in advance!
Regarding the load-bearing capacity of the IKEA PLATSA shelves, the following information is available:
- The shelves are made of melamine-coated engineered wood (particleboard), which generally offers moderate strength but is not comparable to solid wood shelves.
- Manufacturer specifications typically indicate a maximum load capacity of 15–20 kg per shelf, depending on the length and width of each shelf unit.
- Installing a center support beam is recommended to prevent sagging of the shelves under load.
- Tests and user reports show that the construction is suitable for everyday use when properly assembled and subjected to limited loads.
Compared to the IKEA KALLAX system, PLATSA shelves are more flexible in customization but tend to be slightly less robust due to the materials used. KALLAX uses thicker particleboard, which increases its load capacity.
In summary, PLATSA shelves are well suited for moderate loads in living spaces, but not for heavy equipment or large book collections without additional reinforcements.
I would like to add some more details:
First, regarding the material structure: The PLATSA shelves are made of particleboard, which means wood chips pressed together with a binder. These panels are coated with melamine, which protects the surface but does not significantly increase load-bearing capacity.
In everyday use: The load capacity strongly depends on how the shelves are installed. There are basically two types:
- Shelves without a center support: Here, the load per shelf section should not exceed about 10-15 kg (22-33 lbs), depending on the width. Otherwise, the wood will start to bend, especially over larger spans.
- Shelves with a center support: The additional support in the middle distributes the load better, allowing the shelves to easily carry 20 kg (44 lbs) or more.
Tip: It is important to follow the assembly instructions carefully, as incorrectly installed connectors or missing back panels can weaken the overall structure. Using back panels also stabilizes the system further.
Compared to the KALLAX system:
That sums it up well. KALLAX uses thicker and more continuous panels, which is especially better suited for heavy bookcases.
My recommendation: For everyday use and moderate loads, PLATSA shelves are sufficient; for higher demands, it is better to add reinforcements or choose a different system.
jaanda schrieb:
Compared to the IKEA KALLAX system, PLATSA shelves are more flexible in terms of configuration, but tend to be slightly less sturdy due to the materials used.
