ᐅ How sturdy are the drawer runners in the Ikea Brimnes series?
Created on: 24 Mar 2020 08:34
Gillesti
Gillesti
24 Mar 2020 08:34
Hello everyone, I have a question regarding the durability of the drawer slides in Ikea Brimnes. Specifically, I am interested in how strong and long-lasting the metal side-mounted drawer slides are. I am considering purchasing the complete Brimnes set and would like to know if these slides remain stable with daily use or if users have already experienced any warping, sticking, or issues due to material fatigue. It would also be helpful to know how manageable the drawers are in terms of weight and whether overloading them causes any problems with opening and closing. Does anyone have long-term experience or technical knowledge about the materials used and the manufacturing quality? Thank you in advance!
cecile65
24 Mar 2020 09:12
The drawer slides from the Ikea Brimnes are made of basic metal and work well under normal load.
Common issues usually occur only with overloading or when dirt or dust accumulates on the slides.
So, if you have typical everyday use, the stability is satisfactory.
Alberto51
25 Mar 2020 11:27
Gillesti schrieb:
It would also be interesting to know how manageable the drawers are in terms of weight and whether excessive loading causes issues with opening and closing.
I can confirm this from my own experience. After about a year of heavy use, I noticed a slight deformation in the drawer slides, which noticeably made opening more difficult.
At first, I was unsure whether this was due to the installation or the material, but I never overloaded the drawers. Sometimes I wonder if the material is really durable enough to withstand long-term use.
It’s a shame, because I really like the Brimnes design visually, but I am planning to install a more robust solution in the long run. Maybe this helps as a reference point for your decision.
Donar34
26 Mar 2020 14:05
cecile65 schrieb:
The drawer slides on the Ikea Brimnes are made of simple metal and work well under normal load.
Let’s break down the topic systematically: The drawer slides in the Brimnes are indeed basic metal slides with ball bearings. The material and design are intended for typical household use.
- Load capacity: According to the manufacturer, the maximum load capacity is in the mid single-digit kilogram range per drawer. This is sufficient for clothing, light items, and toys.
- Durability: With normal use, meaning no overloading and proper installation, the slides usually last for several years.
- Issues: Sticking or catching drawers are generally caused by incorrect installation, dirt in the slides, or overloading.
Upgrading to high-quality ball bearing heavy-duty slides is possible if higher demands are required. Overall, the construction is appropriately sized for the design and price.
