ᐅ How sturdy are Billy shelves when subjected to frequent heavy use?
Created on: 18 Feb 2021 09:12
Gottfriedg
Hello everyone, I recently bought a couple of Billy bookcases from IKEA to reorganize my home office. I have a key question that I’d like to discuss in detail in this forum: How stable are Billy bookcases under frequent and significantly above-average loads? Specifically, I’m wondering if these shelves can support heavy books, binders, or other items over extended periods without stability issues such as sagging shelves, wobbling of the entire unit, or even damage to the joints.
I’m also interested in which factors have the greatest impact on the stability of the Billy bookcase (for example, wall mounting, number of shelves, distribution of loads) and whether there are effective upgrades or reinforcements that can noticeably improve their load capacity.
I look forward to hearing concrete experiences, technical assessments, and tips!
moses
19 Feb 2021 08:27
Just a quick addition: If the shelf ever starts to wobble, it often helps to tighten the screws and wall plugs and check the wall brackets. This requires little effort and frequently restores a lot of stability. I have even personally replaced individual boards when they began to sag.
Gottfriedg
19 Feb 2021 09:54
GUSTAVO56 schrieb:
If you like, I can also give you tips on how to properly level shelves on uneven floors to prevent any twisting.
That would be great, thanks! My room floor is slightly uneven, which makes me a bit uncertain, especially with heavier loads, because I’m worried it might worsen stability issues. Do you have any specific recommendations on how to compensate for this or address it during installation?
GUSTAVO56
19 Feb 2021 10:30
Gladly! With uneven floors, the goal is to ensure that the shelving unit rests fully and without stress on all feet to avoid twisting.
Here are my tips:
- Use small wooden wedges under the feet if the floor is slightly uneven.
- Adjustable furniture feet (screw feet) can be attached directly.
- Check the levelness with a spirit level during assembly and adjust before final fixing.
- Weighted supports such as rubber pads can help prevent movement on smooth floor surfaces.
This relieves the screws and prevents twisting that could otherwise permanently weaken the shelving structure.
