ᐅ How stable are IKEA BRIMNES furniture pieces during minor vibrations?
Created on: 21 Feb 2018 14:23
Kido56
Hello everyone, I am currently researching furniture safety, specifically regarding IKEA products. My specific question is: How sturdy are the IKEA Brimnes furniture pieces, especially dressers and cabinets, when exposed to minor shocks? I mean everyday vibrations or impacts, such as door closings, light bumps that can occur during rearranging, or small vibrations caused by pets or children in the room. I am particularly interested in how stable the construction is under these conditions, whether the furniture is prone to tipping, if connections may loosen, or if the materials are at risk of damage. I have heard about issues with twisting or warping in other furniture and would like to know if this is a concern with Brimnes. Thanks in advance for your experiences and insights!
I think the question needs to be framed a bit differently: How sure do we WANT cheap furniture to be?
Brimnes is an affordable furniture line designed for easy assembly, transportability, and low price. This means you have to make clear compromises in terms of durability compared to solid wood furniture.
That’s true, but it does not guarantee absolute resistance to shocks – and this is something to keep in mind when buying and using it. A light impact is unlikely to cause a total failure, but what about long-term stability with frequent shocks, screw fatigue, and material stress? In those areas, this furniture is not a top contender.
Just the fact that it avoids solid wood already plays a role, so you shouldn’t expect too much.
olivernu schrieb:
Basically, BRIMNES furniture is designed for normal household use.
I think BRIMNES is great! I have a few dressers and a bed from that line myself.
Of course, you need to pay attention to wall mounting, but with minor vibrations, as you asked, I’ve had absolutely no problems.
The furniture is quite sturdy when assembled properly. I’ve had visitors with children and pets playing around in the room several times, and nothing has happened!
So, no need to worry—just assemble and secure it correctly, and you’ll be happy with it!
ottilie schrieb:
BRIMNES is an affordable furniture range designed specifically for easy assembly, transportability, and cost-effectiveness.This is an important point that I would like to emphasize. Inexpensive furniture like the BRIMNES series is designed to remain stable under normal use but is not intended to withstand frequent heavy impacts.
For users with higher stability requirements, I recommend the following:
- Always secure furniture to the wall
- Regularly check and tighten all screw connections
- Avoid frequently moving or repositioning the furniture whenever possible
These measures help extend the furniture’s lifespan and prevent weak points.
