ᐅ How stable are IKEA BRIMNES furniture pieces during minor vibrations?
Created on: 21 Feb 2018 14:23
Kido56
Kido56
21 Feb 2018 14:23
Hello everyone, I am currently researching furniture safety, specifically regarding IKEA products. My specific question is: How sturdy are the IKEA Brimnes furniture pieces, especially dressers and cabinets, when exposed to minor shocks? I mean everyday vibrations or impacts, such as door closings, light bumps that can occur during rearranging, or small vibrations caused by pets or children in the room. I am particularly interested in how stable the construction is under these conditions, whether the furniture is prone to tipping, if connections may loosen, or if the materials are at risk of damage. I have heard about issues with twisting or warping in other furniture and would like to know if this is a concern with Brimnes. Thanks in advance for your experiences and insights!
O
olivernu
21 Feb 2018 15:07
Kido56 schrieb:
How safe are the IKEA BRIMNES furniture pieces, especially dressers and cabinets, when exposed to minor shocks?
BRIMNES furniture is generally designed for regular household use. Minor shocks, such as those caused by pets or occasional bumps, are not a problem as long as the furniture is properly assembled and secured to the wall.
- Wall mounting is, in my opinion, essential because the relatively slim design increases the risk of tipping otherwise.
- The fittings can withstand considerable loads, but over time the joint strength may decrease if the furniture is frequently moved or heavily loaded.
Overall, I would describe the furniture as stable under minor shocks, but without wall mounting or if assembled improperly, the risk of damage and instability increases.
JEREMIAH38
21 Feb 2018 16:22
Kido56 schrieb:
I am mainly interested in how stable the construction is under such loads, whether the furniture can easily tip over, if joints may loosen, or if the materials are at risk of damage.
From my own experience, I can say that my BRIMNES wardrobe remains quite sturdy during minor vibrations. It hasn’t tipped over so far, but I have always assembled it according to the instructions and secured it to the wall.
What I find interesting is that in households with children, the real risk of tipping is present if the furniture is not fixed properly. I have noticed a slightly loose floor screw twice, but this happened after moving it heavily and was quickly fixed.
I would have serious concerns about using furniture without wall mounting in homes with children, as the stability can then become questionable.
Roberta
21 Feb 2018 16:45
BRIMNES furniture is not ideal without wall anchoring when exposed to vibrations.
I always recommend:
- Proper assembly of the furniture
- Always using wall anchors
This significantly reduces risks.
O
olivernu
21 Feb 2018 17:12
Roberta schrieb:
BRIMNES furniture is indeed not ideal without wall anchoring when exposed to vibrations.
Exactly, that is a key point.
Additionally, I would recommend using felt pads or non-slip mats under the furniture if the floor is very smooth. This helps prevent unwanted sliding and reduces stress on the joints. It can be especially useful for vibrations caused by pets or children playing.
SARBLA1
22 Feb 2018 09:18
I would like to add that BRIMNES furniture uses a carcass construction with wood-based panels, which can quickly lead to material fatigue under strong vibrations.
However, with minor vibrations typical in everyday environments, the stress is very low. It is actually important that the furniture is properly assembled, screws with anchors are tightened securely, and wall mounting is used. IKEA’s connector fittings are designed for long-term use, but they can loosen if the furniture is frequently moved.
For households with children or pets, it is worth regularly checking that all screws are still tight.
