ᐅ What is the maximum load capacity per shelf for Billy shelving units?
Created on: 6 Sep 2022 14:07
Kupidan
Kupidan
6 Sep 2022 14:07
I have a somewhat specific question regarding the load-bearing capacity of the shelves in the Billy bookcase. Specifically, I’m interested in how much weight a single shelf can hold before there is a risk of it bending or getting damaged.
Since I plan to store some fairly heavy books and items on it, I want to make sure I don’t overload the shelf. If anyone has firsthand experience or maybe even official information from IKEA, I would be very grateful. Are there differences depending on the shelf size or material thickness?
Thanks in advance for your help!
KNUTGI
6 Sep 2022 14:23
Hi!
Good question! 🙂 I once read that a single Billy shelf can hold about 30 kg (66 pounds) before it becomes critical – but of course, it always depends on how the load is distributed. If you spread the items evenly, it works better than stacking everything in the middle.
I also use mine for books and haven’t had any issues, but I usually stick to around 25 kg (55 pounds) per shelf to be on the safe side. As far as I know, Ikea doesn’t offer thicker shelves, but you could add extra supports to increase stability a bit.
So, don’t overdo it, but Billy is surprisingly sturdy! 😉
kulau
6 Sep 2022 15:08
Wow, interesting question with a lot to consider. The maximum load capacity of a Billy shelf board depends not only on the official specifications but also on several factors:
1. Material and thickness of the board – Billy shelves typically use particleboard with a melamine surface. The load capacity is often around 30 kg (66 lbs), but long-term loading can also cause sagging.
2. Shelf width – wider shelves (e.g., 80 cm (31.5 inches)) will sag more than narrower ones (e.g., 40 cm (15.7 inches)) because of the greater span.
3. Load position – a concentrated load in the middle stresses the shelf more than a uniformly distributed load.
4. Condition of the shelf – older or moisture-exposed particleboard can lose stability.
Ikea states about 30 kg (66 lbs) per shelf as a guideline, assuming the load is evenly distributed. For heavier loads, it’s advisable to add additional supports underneath or consider alternative shelving systems with thicker boards.
How heavy are your books or items exactly? And what is the width of your Billy shelf?
Kupidan
6 Sep 2022 15:27
kulau schrieb:
How heavy are your books or items specifically?
Thanks in advance for the detailed response!
My Billy bookshelf is 80cm (31.5 inches) wide and is placed against the wall in a relatively dry room. The books weigh between 20 and 35 kilograms (44 and 77 pounds) per shelf – but I prefer to be on the safe side and avoid any risk of the shelves bending, especially since I want to use the shelf long-term.
Are there any tips on how to increase the load capacity without having to replace the entire bookshelf? Or would it be advisable to switch to a different shelving system if you plan to store heavier loads permanently?
BAUEVA
7 Sep 2022 09:12
I appreciate that this topic is being discussed in depth.
Just to clarify: The 30 kg stated by IKEA refers to the so-called "maximum load with even weight distribution" and is based on standardized tests. It should be considered more as a rough guideline.
KNUTGI schrieb:
I once read somewhere that a single Billy shelf can hold about 30 kg
That is basically correct, but it is important to strictly differentiate between short-term loads and permanent loads. Material defects and aging also play a role.
If the goal is to increase the load capacity, the most efficient solution would be to add additional central supports under the shelves. This significantly reduces the span and prevents sagging. Alternatively, the shelves can be replaced with wood panels of higher strength, but this usually voids the warranty.
Therefore: It is a balance between cost, effort, and safety. For books weighing about 35 kg per shelf at an 80 cm (31.5 inch) span, the original Billy shelves are indeed already at their limit. I recommend distributing the weight more evenly or reinforcing the shelf accordingly.
liRaul49
7 Sep 2022 10:03
The maximum load capacity per Billy shelf board is 30 kg (66 lbs) with evenly distributed weight. With heavier loads or prolonged use, the shelf may bend.
Reinforcement can be done using additional center supports or thicker shelf boards. Otherwise, it is better to load less.
