I recently bought a Hemnes chest of drawers set from Ikea and have noticed that the drawers seem a bit unstable under heavier loads. My question to the experienced users here is: How exactly can the Ikea Hemnes drawers be reinforced?
I mean, which steps are technically sensible and practical to improve the stability and load capacity of the Hemnes drawers without fundamentally changing the original design?
Are there specific materials or reinforcements (e.g., metal brackets, wooden strips) that have proven effective? And how should these be installed so that the drawer systems continue to operate smoothly without jamming?
I already have some technical knowledge but would appreciate concrete practical instructions, experience-based advice, and recommendations — including tips on common mistakes to avoid. Thanks in advance for your support!
first, regarding the basic structure: The Ikea Hemnes drawers are mainly made from glued MDF and particleboard panels, which allow for moderate load capacity but can become problematic under heavy use.
For reinforcement, I recommend the following approach:
- Use thin metal brackets on the inside corners of the drawers to stabilize the connections of the drawer walls.
- Additionally, small wooden dowels or screws can be installed internally, which should be fixed beforehand with wood glue to minimize movement.
- If possible, reinforce the drawer base with an additional wooden board (e.g., plywood) to prevent sagging.
Important: These measures should be installed in a way that they do not interfere with the drawer slides or runners to ensure smooth closing.
By following these recommendations, the load capacity of the Hemnes drawers can be significantly increased.
Hello Nar-far,
here is a brief guide on reinforcing Hemnes drawers:
1. Disassembly: Pull the drawer completely out and place it on a clear workspace.
2. Inspection: Check all edge joints for any loose spots; remove old glued wood if necessary.
3. Reinforcement:
- Screw metal corner brackets into the four corners inside.
- For the bottom, I recommend cutting a thin plywood panel to fit precisely and attaching it from underneath.
4. Assembly: Screws should not be too long, maximum 15 mm (0.6 inches), as the panels are relatively thin.
5. Installation: When putting the drawer back into the slides, make sure no screws interfere with the drawer’s movement.
Common mistakes:
- Screws that are too long, damaging the drawer front.
- Installing brackets on the outside, which affects the appearance.
Summary: Using metal corner brackets inside and adding bottom reinforcement will help secure and improve the drawer’s load capacity. Pay attention to precision during installation.
3. Reinforcement:
Common mistakes:
Landontau24 Mar 2022 14:41Jensson schrieb:
Common mistakes:
- Screws too long, damaging the drawer front.
- Attaching brackets on the outside, which spoils the appearance.This is an important tip. I would add that you should also be careful with material selection. For wooden trim, solid beech wood or plywood is recommended, as these types of wood are more stable and less prone to movement than MDF.
Furthermore, I advise checking the fit of the reinforcement parts carefully – there is little use in misshapen material that then causes pressure marks on the side panels.
If the drawers need to carry a lot of weight, you might also consider building a small, internal frame from wooden strips, mainly supporting the long side of the drawer. This noticeably increases load capacity.
However, you should always ensure that the drawer dimensions and clearance space within the slides are maintained.
CHENFAR schrieb:
Important: These measures should be installed in a way that does not interfere with the running tracks or drawer slides to ensure smooth closing.This exactly addresses the issue I often find problematic with IKEA furniture: you want to reinforce it, but you’re afraid of making the original sliding action worse.
From my own experience, it is usually imprecise reinforcements and pressing materials that cause drawers to stick. My advice is to work with thinner materials and, above all, to ensure a precise fit so that nothing warps.
Even if the drawers are older, the metal runners can be worn, which creates a feeling of instability. It’s good to check these before working on the drawer itself.
