ᐅ How can BILLY shelves be protected against moisture in rooms with poor ventilation?
Created on: 6 Nov 2016 08:43
dumapeo
dumapeo
6 Nov 2016 08:43
I’m looking for effective ways to protect IKEA BILLY shelves from moisture damage, especially in rooms with poor ventilation. The classic particleboard used in BILLY shelves is known to be sensitive to moisture, which can cause swelling or warping quickly in areas with high humidity or condensation.
I’m particularly interested in practical solutions that can be implemented easily without having to rebuild the entire shelf. Possible options might include special sealants, moisture barriers, or other technical tricks to reduce the problem over the long term.
Do you have any experience or tips on how to protect these shelves cheaply and effectively? Are there any useful tricks related to the placement of the shelves or controlling the indoor climate that might help? I look forward to your opinions and advice!
jakar
6 Nov 2016 09:18
Simply apply waterproof paint or varnish to the back and edges.
Then control the indoor humidity with a dehumidifier.
This will largely prevent swelling.
Nicksin
7 Nov 2016 11:07
jakar schrieb:
Then regulate indoor moisture using a dehumidifier.
Absolutely, dehumidifiers work wonders when it’s hard to control indoor humidity. But for someone who doesn’t want to run devices all the time, a simple method can also help: place the shelf on small spacers, such as felt pads or suitable underlays, to prevent the feet from standing directly on cold floors—this way, rising moisture and condensation have no chance to penetrate directly.
Additionally, you can protect the sensitive wood surfaces with clear varnish. Alternatively, there are special wood protection sprays available. It’s a matter of personal preference which you prefer.
What I also like to do, if it fits, is place some natural moisture absorbers in front, like simple silica gel packets or small bowls of salt. Quite simple and often works pretty well.
Issac_kla2
8 Nov 2016 14:26
Nicksin schrieb:
place a few natural moisture absorbers in front, like simple silica gel packets or small bowls of salt.
Sure, that might work for a few days with low humidity, but it definitely won’t keep things stable over the long term in a poorly ventilated room. The particleboards simply absorb too much moisture, and that’s physically almost impossible to prevent without replacing the material or fully sealing it.
I think we often overestimate these little tricks and overlook the real problem: poor ventilation and using the wrong materials for such conditions. Why not switch directly to moisture-resistant shelving or metal if you want to be safe anyway? It’s not magic, just reality.
Of course, I understand that people like the affordable BILLY shelves—but struggling with sealants or salt containers here is, in my opinion, a waste of time. My provocative view: the longer you use such shelves in “problematic” rooms, the faster you’ll run into trouble. And that’s only accepted because of the low price.
