ᐅ How do you clean Billy bookcases compared to other types of furniture?
Created on: 30 Apr 2022 08:12
Cem-jon
I am interested in this thread in learning the best way to clean Billy bookcases compared to other types of furniture. I am not just thinking about regular dusting but also about special cleaning methods that protect the material and preserve the surface over time. Unlike solid wood furniture or other laminate furniture, the Billy bookcase seems more sensitive to incorrect cleaning products or methods because of its particleboard core with a foil coating. Does anyone have experience with removing stains without damaging the edges or surface? And how does the care for the Billy bookcase differ from other typical furniture found at home?
Paunon
30 Apr 2022 14:17
Stains like coffee can be removed from Billy with a mild cleaner and immediate wiping. Never let it soak. For grease, sometimes a little dish soap and warm water can help.
theo63
1 May 2022 07:55
Surela schrieb:
In contrast, solid wood furniture often benefits from a special wood care product that can tolerate small amounts of moisture and penetrates into the wood.
This clearly illustrates the difference in material maintenance. But perhaps it’s also a matter of the furniture’s lifespan? Billy-type shelving units are often inexpensive and not primarily designed for long-term care. That would also justify the simpler cleaning methods without the need for much effort or expensive products.
Jodyro
1 May 2022 09:12
For the Billy, I just use a dust cloth and warm water. For other furniture, I sometimes use a specialized cleaner. It's as simple as that.
Friedrich
1 May 2022 10:36
I think it’s good that the sensitivity of surfaces is mentioned here. I have experienced firsthand how quickly improper cleaning can damage somewhat durable laminate surfaces. At first, I was worried that the material of the Billy shelf might swell due to moisture, but with careful cleaning it has held up well. What has helped me so far is acting quickly when stains appear and never using too much water.
Lotizar
2 May 2022 08:28
Friedrich schrieb:
Act quickly on stains and never use too much water.
These two points are crucial, especially with so-called edge banding like on Billy. Moisture can penetrate the material negatively, even if it is coated. For this reason, cleaning in practice differs significantly from solid wood or real wood furniture with an open pore structure.
DEOLAU
2 May 2022 09:45
In summary, it is advisable to clean Billy shelves only with a soft cloth and mild cleaners, and to always dry them promptly. For other furniture, different care products are used depending on the material. I follow this approach and have not experienced any stains or damage so far.
