ᐅ How do you properly remove dust from Billy shelves?
Created on: 11 Jul 2020 09:23
kairo6
kairo6
11 Jul 2020 09:23
I have a rather specific question about cleaning and dust removal for furniture, especially the Billy shelves from IKEA. How should the Billy shelves be properly cleaned to remove household dust without damaging the surface or material?
I am particularly interested in effective methods to thoroughly remove dust from the corners and edges of the shelves. This includes both the use of cleaning agents and suitable tools or aids.
Additionally, I would like to know if there are any special care instructions I should follow during cleaning to keep the shelves looking good for a long time and to avoid stains or damage.
I would be very grateful for any tips and personal experiences!
Kabau
11 Jul 2020 10:10
To remove household dust, I recommend using a microfiber cloth. It is best to use it dry or slightly dampened. For corners, a soft brush can be used. Avoid harsh cleaning agents, as they usually damage the material.
FAZAR
11 Jul 2020 11:45
To effectively remove household dust from Billy shelves, a multi-step process is recommended. First, use a vacuum cleaner with a brush attachment to remove loose dust, especially in corners and edges that are hard to reach. Next, wipe the shelf with a lightly dampened microfiber cloth. It is important not to use large amounts of water, as the chipboard of the shelf can absorb moisture and swell.
This is a very important point. Avoid organic solvents or abrasive cleaners. Instead, you can prepare a mild dish soap solution. Also, make sure to wring out the cloth well to prevent any moisture from accumulating.
Finally, I recommend wiping the shelf with a dry cloth after damp cleaning to remove any remaining moisture. For corners, you can use small brushes or specialized cleaning brushes.
Could you also let us know how much space you have to possibly disassemble the shelf for cleaning? Sometimes removing the shelves helps to clean more thoroughly.
enrique7
11 Jul 2020 12:30
I find it interesting that the cleaning of Billy shelves is often only considered in terms of surface cleaning. However, there is also the issue of dust accumulating behind back panels or in hard-to-reach areas. To what extent can one actually ensure that the cleaning is truly thorough if you don’t disassemble each part?
FAZAR schrieb:
Can you also say how much space you have to possibly take the shelf apart for cleaning?
That hits the core of my question: In smaller apartments, it is often not possible to fully dismantle a shelf or move it to another location. Therefore, I am waiting for practical tips on how to achieve good results here with minimal effort.
Additionally, I wonder if certain materials or surface treatments of the Billy shelves respond differently to moisture absorption and thus wear out faster. Does anyone know a reliable source or manufacturer information on this?
julian36
11 Jul 2020 14:02
A systematic cleaning of Billy shelves should be done according to the manufacturer’s instructions from IKEA. The shelves are made of particleboard with a melamine resin hard coating. This means they are generally resistant to light moisture but must not get wet.
The proper procedure is:
1. Dry wipe with a soft, lint-free cloth or microfiber cloth
2. For stubborn dust and dirt, use a damp cloth with lukewarm water (optionally with a drop of mild dish soap)
3. Wring the cloth out well to avoid moisture
4. Immediately dry wipe after cleaning
Tools such as small dusters or brushes can help loosen dust in corners. Additionally, vacuum cleaners with upholstery or brush attachments are useful.
enrique7 schrieb:
In kleineren Wohnungen ist es häufig gar nicht möglich, ein Regal komplett abzunehmen oder an einen anderen Ort zu bringen.
Then cleaning in situ obviously makes sense. There are also special vacuum cleaner extension tubes available to better reach hard-to-access areas.
Avoid abrasive cleaners or chemical detergents that could damage the coating.
Glage
11 Jul 2020 16:17
I can easily understand how annoying dust on Billy shelves can be, especially if you have allergies. What helps me is wiping the shelves more frequently at short intervals with a dry cloth, as this prevents dust from settling too much.
If you are concerned about moisture, I would recommend using a spray nozzle on a spray bottle and lightly dampening the microfiber cloth instead of spraying directly onto the shelf.
This reduces the risk of the shelf becoming too wet while still allowing for thorough cleaning.
What also works well for me is keeping the surrounding area clean by regularly vacuuming and airing out the room to minimize dust buildup.
enrique7 schrieb:
In smaller apartments, it is often not possible to completely remove a shelf or move it to another location.
I know that well – often you can’t move much.
