ᐅ How can you make Malm furniture more durable?
Created on: 20 Jan 2023 19:47
hidayetbar
hidayetbar
20 Jan 2023 19:47
I have several IKEA Malm furniture pieces that I like a lot, but I’ve noticed they can be quite delicate in everyday use. My question is: How can Malm furniture be made more resistant to scratches, wear, and moisture without completely rebuilding or replacing it? Are there proven methods or treatments for the surface that strengthen or protect the material, and if so, what is the best way to apply them? I’m looking for durable solutions that can be done by myself without needing special tools or expensive professional products.
Roberta
20 Jan 2023 20:12
Basically, a clear protective layer such as furniture oil or wax helps to reduce scratches. For added stability, it is also recommended to regularly check the furniture and tighten screws. In case of moisture, impregnation is advisable.
KNUTGI
21 Jan 2023 09:33
Hey, Malm furniture is known for not being built to last forever 😅. But with a bit of care, you can really spruce it up! Try sealing the surfaces with hard wax or a clear varnish; it offers great protection against scratches and moisture. Oh, and those felt pads under the legs are a must-have—they prevent annoying squeaking and damage to the floor 😉. Just do it, and your pieces will last much longer!
Nathanaelk
21 Jan 2023 21:47
Very good question!
Regarding the durability of Malm furniture, which mainly consists of particleboard with a thin laminate or lacquer coating, the following applies: The biggest weak points are the surfaces and especially the edges, as moisture can quickly penetrate there and cause swelling of the material.
1. Surface treatment: An additional protective layer of hard wax or polyurethane varnish can make the surface significantly more resistant to scratches and liquids. The varnish should be applied in thin layers and fully cured, ideally in a well-ventilated room.
2. Edge sealing: The edges should be treated with a special edge protection varnish or clear lacquer that remains flexible to prevent cracking due to temperature changes. This procedure significantly prolongs the lifespan of the furniture.
3. Screw inspection and reinforcement: Malm is often assembled with dowels and screws – it is worthwhile to check the connections and, if necessary, use stronger screws or metal brackets for stabilization. This reduces the risk of wobbly furniture and increases load capacity.
4. Avoid moisture: If the furniture is placed in more humid rooms, additional moisture protection sprays or specific wood impregnations should be used.
I would specifically ask about the construction: What kind of surface do you have? Is it laminate, veneer, or lacquered wood? Depending on the material, the treatment may vary.
hidayetbar schrieb:
Wie macht man Malm Möbel widerstandsfähiger gegen Kratzer, Belastungen und Feuchtigkeit
Because the exact surface characteristics are key here for choosing the protection method.
