ᐅ How do you securely attach Ikea Pax wardrobes to drywall (gypsum board) walls?
Created on: 5 Aug 2023 09:17
Geneviev67
Hello everyone, I am currently planning to assemble an Ikea Pax wardrobe in a room with drywall (gypsum board) walls and want to secure it safely. The problem is that drywall walls do not have the same load-bearing capacity as solid walls, which makes me cautious. My question is: How do you properly and securely fasten Ikea Pax wardrobes to drywall so that they stand stable and do not tip over or damage the wall? Which fasteners are recommended, and are there any specific techniques or precautions to consider? I look forward to your experiences and advice!
Curtis
6 Aug 2023 09:35
A question about load distribution: Is it really sufficient to screw only into the studs of the drywall when the cabinet is fully loaded? Would an additional floor support not make the entire structure significantly more secure? Ikea itself often recommends in their assembly instructions a fixed wall anchor plus floor contact. Otherwise, there could be dangerous tipping movements.
Joshbe
6 Aug 2023 10:56
Curtis schrieb:
One question about load distribution: Is it really sufficient to only screw into the studs of the drywall when the cabinet is fully loaded?
.My sober assessment: Fastening solely to metal studs is a good starting point but not always the safest option. The risk of tipping remains, and the cabinet puts continuous strain on the mounting. Having firm contact with the floor is recommended for structural reasons, even if the Ikea Pax systems are not explicitly designed for this.
Curtis schrieb:
Would an additional floor support not make the entire setup significantly more secure?
Absolutely, combining wall mounting with an additional support or foot underneath the cabinet reduces leverage and significantly improves stability. Ceiling mounting as an extra safety measure is also possible.
nubar
6 Aug 2023 14:12
For a secure result, the multipoint fastening concept is crucial: - Attach at least two points on the wall, preferably to the load-bearing studs of the drywall - Use tested cavity anchors (e.g., metal toggle bolts) - Consider the floor load and position the cabinet so that it stands stable - If possible, use additional safety brackets or anti-tip devices, such as cabinet clamps.
This not only reduces the risk of wall damage but also prevents the furniture from tipping over.
eldubi
7 Aug 2023 08:55
In summary: Screw toggle bolts into metal profiles, place the cabinet directly on the floor, and additionally secure it to the wall. This reliably prevents the risk of tipping.
