ᐅ How do you securely attach Ikea Pax wardrobes to drywall (gypsum board) walls?
Created on: 5 Aug 2023 09:17
Geneviev67G
Geneviev675 Aug 2023 09:17Hello everyone, I am currently planning to assemble an Ikea Pax wardrobe in a room with drywall (gypsum board) walls and want to secure it safely. The problem is that drywall walls do not have the same load-bearing capacity as solid walls, which makes me cautious. My question is: How do you properly and securely fasten Ikea Pax wardrobes to drywall so that they stand stable and do not tip over or damage the wall? Which fasteners are recommended, and are there any specific techniques or precautions to consider? I look forward to your experiences and advice!
When mounting Ikea Pax wardrobes on drywall (plasterboard) walls, it is crucial to use appropriate anchors and screws that are approved for the cavity and material. Here is a structured approach:
- First, locate the drywall studs (metal or wood framing) behind the wall, ideally using a stud finder.
- Pre-plan the back panel of the Pax wardrobe at the points where it will be attached.
- For anchors, I recommend high-performance hollow wall anchors (e.g., toggle bolts or expansion anchors suitable for drywall). Standard plastic anchors are usually not suitable.
- Screws should be long enough to securely hold through the wardrobe, drywall, and anchor.
- Properly install the mounting brackets of the Pax wardrobe, often spaced about 100-150cm (40-60 inches) apart.
- If possible, prefer more complex solutions, such as adding cross braces behind the drywall panel.
It is also important not to hang the weight of the furniture solely on the wall but to use the floor as support to distribute the load.
Mounting on drywall (plasterboard) walls can be challenging because standard wall anchors often are not sufficient. Based on my experience and technical literature, I recommend the following steps:
1. Check the condition of the wall: How thick is the drywall panel? 12.5 mm (0.5 inches) is standard, but thinner panels or multiple layers may have different values.
2. Use only special heavy-duty anchors designed for hollow walls, such as toggle bolts or metal hollow wall anchors. The difference is that these provide significantly higher load capacity than standard anchors.
3. Make sure to locate the studs behind the drywall. Directly screwing into the studs is always the most secure option and supports much greater loads.
4. If the planned position of the cabinet does not align with a stud, reinforcing the wall is advisable. This can be done by attaching an additional wooden batten to the wall, fixed with suitable anchors, onto which the cabinet will later be mounted.
5. Always fill any anchor holes properly with suitable filler material to prevent cracking.
6. Be aware of the maximum weight of a fully loaded Pax-style cabinet – a fully loaded cabinet can easily weigh 100 kg (220 lbs) or more. For cabinet widths from 100 cm (39 inches) and above, fastening at a minimum of two points is mandatory.
An addition: It is especially important to secure the wardrobe to prevent it from tipping over. The Ikea Pax systems include pre-assembled hanging brackets that can be attached to the top frame. These must be firmly fixed to the wall. For drywall (plasterboard) walls, this means the brackets need to be anchored with cavity anchors directly into the studs or solid reinforcements. Alternatively, if wall mounting is problematic, the wardrobe can be secured against tipping by attaching a safety device to the ceiling. This significantly increases stability.
jan10 schrieb:
Use toggle bolts for drywall, locate the metal studs, and fasten there. That is a good principle, but not always sufficient: the spacing of studs in standard drywall walls is often 60 cm (24 inches), which depending on the size of the cabinet means only a few fixing points. Therefore, I recommend installing additional reinforcements where possible, for example by adding cross braces behind the wall or using mounting plates. This helps distribute the load better and reduces the risk of wall damage.
