ᐅ How do you install additional storage inside a Pax wardrobe system?
Created on: 17 Apr 2022 09:13
maklo30Hello everyone,
I am currently looking into the best ways to add extra storage options inside an IKEA Pax wardrobe without damaging the existing system or losing flexibility. Specifically, I am interested in methods for attaching additional shelves, small hooks, or storage bags inside the Pax. It is important to me that the attachments are sturdy enough to support heavier loads in the compartments.
Additionally, I would like to know if you have any experience with DIY solutions and whether there are particular materials or tools that work especially well for this purpose. Tips on how to make good use of the original wardrobe structures—such as the peg holes for shelves—without causing damage or risking the warranty would also be very helpful.
I look forward to your recommendations and advice on common mistakes to avoid when upgrading the wardrobe.
Hello maklo30,
Regarding your question about how to attach additional storage inside a Pax wardrobe, there are proven methods that don’t require major modifications to the furniture:
- Using the existing row of holes: IKEA Pax units come standard with side holes designed for shelves or accessories. Extra shelves can be added here using compatible brackets. These brackets are ideal for hanging modular boxes or baskets.
- Using clamp fittings or clip-on holders: For lighter items, clamp fittings that attach to the edges without drilling are suitable. These are gentle on the furniture and can be removed without leaving marks.
- Magnetic or hook-and-loop (Velcro) storage pouches: If flexibility is the priority, these options offer easy attachment to metal surfaces or smooth interior walls. However, it’s important to check the carrier materials, as not all solutions are compatible with the Pax inner surfaces.
- Screws and wall plugs should only be used for truly solid and permanent additions, since altering the original structure usually affects the warranty.
Please note that the load capacity also depends on the quality of the accessories used. It’s recommended to use original or compatible IKEA accessories. Custom-built solutions should be tested for a precise fit to avoid unnecessary strain or damage to the wardrobe.
I hope these points help you.
Hello maklo30,
to answer your question in more detail and with a practical approach, here is a step-by-step guide for retrofitting additional storage in the Pax system:
1. Preparation: First, determine the available interior space, the position of the peg holes on the side panels, and the load requirements (e.g., weight of the stored items).
2. Choosing the mounting method:
- For installing shelves and baskets, use only Pax-compatible dowels and shelf supports. These fit perfectly into the pre-drilled holes and provide secure stability.
- Additional hooks can be hung into the peg holes or attached using special clamp or magnetic fasteners.
3. Installation:
- Insert the shelves with appropriate supports into the peg holes. Make sure the supports are perfectly horizontal to ensure stability.
- For storage bags, the use of hook-and-loop adhesive tapes that can be removed without residue is recommended.
4. Avoiding common mistakes:
- Avoid drilling into the material if you do not want to damage the original structure.
- Do not overestimate the load capacity of lightweight clamp solutions.
- Check in advance whether the accessories meet the load requirements.
In summary: It is best to use the Pax system’s original peg hole grid and manageable add-on parts designed for the system. This guarantees safety, preserves the warranty, and allows for flexible modifications.
3. Installation:
FEKAU schrieb:
- Use of the existing row of holes: IKEA Pax furniture comes standard with side holes intended for shelves or accessories. Additional shelves with matching brackets can be added here. These brackets work best for hanging modular boxes or baskets.This statement makes sense, but I wonder: Is it always advisable to rely solely on the pre-drilled row of holes? The stability of these fixtures largely depends on the load-bearing capacity of the shelf supports.
Jensson schrieb:
- Avoid drilling into the material if you don’t want to damage the original structure.I also have reservations about that. There are situations where drilling can be useful to better meet individual needs or to integrate special storage systems that otherwise wouldn’t fit.
It is true that drilling usually voids the warranty, but how relevant is that in everyday use? For someone who plans to use the cabinet for a long time anyway, customized solutions involving drilling or additional screws could offer real advantages in terms of stability and usability.
So: Protecting the system is reasonable, but it would be interesting to also discuss the pros and cons of do-it-yourself modifications (e.g., drilling inside the unit)—especially regarding stability and practical use.
