ᐅ How do Ikea HEMNES shelving systems fit into rooms of different sizes?
Created on: 21 Apr 2015 09:42
nemo35
nemo35
21 Apr 2015 09:42
I would like to start a discussion on the topic of “How do Ikea Hemnes shelving units fit into rooms of different sizes?” I’m especially interested in which factors should be considered when placing and selecting the modules, for example when planning in small, medium-sized, or spacious rooms. Are there practical experiences or tips on how to best size and combine the shelves to achieve both functionality and a harmonious spatial feel? I also find it particularly important to understand how flexible the Hemnes system is in rooms with sloped ceilings, alcoves, or varying ceiling heights. I look forward to well-structured contributions that refer to specific room sizes and conditions, so I can better assess how to optimally furnish my living or working space.
ladali
21 Apr 2015 11:23
The Ikea HEMNES shelving systems are generally very flexible, but due to standardized sizes, there are clear limits. For small rooms (under 10 sqm (107 sq ft)), I recommend narrower and lower modules, such as the 90 cm (35 inch) wide and 197 cm (78 inch) high shelves, to avoid overwhelming the space. In medium-sized rooms (10–20 sqm (107–215 sq ft)), a combination of open and closed elements works well to balance storage capacity and visual lightness. Large rooms (>20 sqm (215 sq ft)) can accommodate wider units and even combine several modules as room dividers. It is important to consider ceiling height: HEMNES shelves come in standard heights but no taller versions are available. In rooms with low ceilings, the 197 cm (78 inch) height can sometimes feel too dominant; here, lower combinations or modifications make more sense. Niches can be effectively filled with individual or customized shelves, while sloped ceilings usually require improvisation, such as using side flexibility and custom dividers.
reybo
21 Apr 2015 14:37
One important technical aspect should not be overlooked: the depth of the HEMNES shelves is usually between 30 and 35 cm (12 and 14 inches), which works well in many rooms, but in very small spaces you definitely need to measure the clearance areas carefully in advance to avoid cramped conditions. A small room often gains storage space with narrow, tall shelves without using much floor area—so think vertically. Especially with sloped ceilings, it makes sense to take precise measurements on-site and possibly place the shelves with the backs removed or open to optimize the spatial effect. The modular doors and drawers also offer flexibility for individual uses. One small note: the HEMNES series is made from solid pine wood, meaning the weight is considerable, especially when stacking or combining multiple units. A secure anchoring to the wall is therefore essential, particularly in larger room configurations.
MOBALI
21 Apr 2015 17:05
For small rooms, I recommend the 90cm (35 inch) wide shelf; for larger living rooms, two or more modules. For ceiling heights under 2.50m (8 ft 2 in), it is better to choose the lower model. Avoid sloped ceilings or adjust the shelving on the side.
nemo35
22 Apr 2015 08:19
ladali schrieb:
With low ceilings, a height of 197 cm (77.6 inches) can sometimes feel too imposing; in such cases, lower combinations or modifications make sense.
That’s a useful tip, thank you. Has anyone had experience with planning under a sloped ceiling of about 1.80 m to 2.10 m (5 ft 11 in to 6 ft 11 in) in height? How flexible are the individual HEMNES pieces in these situations? Can you simply cut taller shelves down, or is that more complicated?
reybo schrieb:
The modular doors and drawers also offer flexibility for customized uses.
How does that affect combinations? Especially when mixing different module depths or heights?
DINASAN
22 Apr 2015 12:46
Regarding questions about the slope: Ikea HEMNES shelves are not modular in terms of individual height adjustments by shortening the side panels, as the system is based on fixed pre-made modules with pre-drilled connection points. Technically, reducing the height is possible, but it involves some risks. You not only lose the warranty, but it can also affect stability, and the veneer will be visible at the cut edge. For sloped ceilings, it is therefore advisable to choose either lower models or open variants with free sections that can be placed under the slope. Alternatively, shelf units without back panels can be used, and the back panel can then be custom-fitted. The HEMNES drawer and door modules can be combined with open shelves, but they must be matched to compatible cabinet depths. Different depths within one system disrupt the overall appearance and create small gaps or tripping hazards. With minor deviations, it is possible to use trim or cover panels as a visual transition. However, a clever combination of several modules can create a flexible look if you plan carefully and adhere to the exact dimensions.
