I have a problem with my Malm bed from Ikea that squeaks quite loudly when moving. I suspect the issue is with the joints or the frame, but I’m not sure how to fix it properly. The squeaking mainly happens when turning over and getting up.
I’ve considered tightening the screws, but what is the best way to do this without causing any damage? Are there any methods or tricks you know to eliminate the squeaking in Malm beds permanently?
Maybe someone also has experience with certain lubricants or pads that can be used? Thanks in advance for your tips!
Mereo schrieb:
The squeaking mainly occurs when turning over and getting up.This is an important observation because it suggests that the noises come from the moving joints. Malm beds typically involve connections made of wood, metal, and particleboard – these can start to creak if the joints develop slight play or if the finish or surfaces wear down slightly.
My suggestion is the following step-by-step plan:
1. Check and tighten screws: Use a suitable screwdriver or Allen key (depending on the model) to inspect all screws and connections according to the assembly instructions – but avoid forcing to prevent damaging the material.
2. Use lubricant: If the screws are tight, I recommend thoroughly cleaning the contact points, then applying specialized lubricants – for example, graphite- or silicone-based sprays that do not harm wood or metal. Do not use WD-40, as it is more for rust protection.
3. Insert pads or felt gliders: Sometimes placing thin pieces of felt or furniture sliders between the joints helps reduce friction and thus the squeaking.
4. Check for damage: Occasionally small cracks or wear may be present, which can possibly be secured with wood glue.
I’m also interested whether the bed stands on an uneven floor or if it seems generally stable? That can better explain the noise development.
If you like, you can share how the bed is assembled and whether you have already disassembled any parts yourself. That makes a more precise assessment easier.
Mereo schrieb:
The creaking mainly occurs when turning over and getting up.To add to PLOMA’s explanation: In Ikea’s Malm beds, most joints are not rigidly glued but connected mechanically with screws and bolts. Over time, these can slightly loosen due to stress, which causes the typical creaking sound.
Here are some practical tips to prevent it:
- First, gently tighten all screws with the recommended tool, usually an Allen key. Be careful not to overtighten.
- Apply a dry silicone-based lubricant to the contact points of the moving parts. This helps minimize friction and leaves no stains.
- Another trick is to place nylon or felt pads between the connection points to permanently eliminate friction noise.
I advise against using conventional oils like WD-40, as they can damage materials and surfaces and sometimes attract dirt.
Also, make sure the bed is on a solid and level floor, since uneven flooring can allow extra movement that promotes noise.
First, check that all screws are really tight, especially on the side panels.
If the bed stands on an uneven floor, level it out with felt pads under the legs.
At contact points, you can apply a thin layer of graphite powder or silicone spray; this reduces squeaking without causing stickiness.
This is usually enough to stop the creaking.
PLOMA schrieb:
I'm interested in whether the bed is standing on an uneven floor or if it generally feels stable?That is indeed one of the main factors. If the bed is not completely stable, small movements at the connection points are amplified, which leads to noises.
If the mattress or slatted frame is too firm or too soft, this can additionally cause movements that increase the squeaking.
Another point is the material of the screws or connectors. When wood moves against metal, friction often occurs, resulting in noises.
Some users report that for Malm beds they replace screws with metal ones combined with rubber buffers or washers between the parts to reduce the noise.
I also recommend performing regular maintenance after extended use – checking screws, tightening them, replacing worn parts if necessary, and lightly oiling the joints.
This will help prevent long-term damage and keep the bed quiet and stable.
