ᐅ How can I securely install Ikea Metod wall cabinets without drilling?
Created on: 11 Apr 2020 09:12
arnim70Hello everyone, I am currently planning to install Ikea Metod wall cabinets in my kitchen and am looking for ways to secure them safely and firmly without drilling into the wall. The usual methods typically require anchors and screws, which is not an option in my rented apartment. Are there practical alternatives to hang Metod wall cabinets without permanent wall drilling? It is important to me that the solution is truly secure so that the cabinets remain reliably in place over time and do not become loose or fall down. Perhaps you know of special brackets, clamping mechanisms, or other tricks that not only work in theory but are also load-bearing in practice. I would really appreciate any tips, experiences, or assessments on this topic.
There are clamp supports that fit between the countertop and the ceiling. This way, you avoid drilling. It is important that the ceiling is stable and the countertop is securely fixed. Metod is designed to be mounted on a wall. Without drilling, the stability is always limited.
To securely install Metod wall cabinets without drilling, it is recommended to use freestanding structures or room dividers with integrated brackets. Alternatively, plug-in systems that attach to the back of the furniture and clamp to the ceiling or floor can be used. It is important to ensure that the load is distributed as evenly as possible and that the cabinets are not subjected to point loads only. Safety testing of such systems is necessary, ideally with load specifications provided by the manufacturer or certified components.
Renegi schrieb:
There are clamp beams that are pressed between the countertop and ceiling.Exactly that! I saw something like this during a small kitchen renovation – it looks very clean and saves the wall. You just need to measure the ceiling precisely to make sure everything fits. If it’s stable, it really makes an impression. 😊
However, especially with taller cabinets, I would pay attention to the weight, as it needs to be properly supported.
Basically, it is important to know that Metod wall cabinets are designed for wall mounting using anchors and screws. Without this type of anchoring, there is always a residual risk regarding stability and safety. However, this does not mean that alternatives are impossible. If drilling into the wall is not desired, freestanding support structures or special tensioning devices can be suitable. In doing so, I recommend paying attention to the following points:
- Load capacity of the supports
- Stability of the floor, ceiling, or countertop
- Even distribution of weight
- Practical disassembly if needed
Also, always ensure that the cabinets are securely fixed, especially when they are intended to hold heavy items.
