ᐅ How can I securely install Ikea Metod wall cabinets on drywall (plasterboard) walls?
Created on: 6 Jan 2018 14:23
lanofra
I am facing the challenge of securely installing Ikea Metod wall cabinets on drywall. Since I am used to solid walls, I want to make sure the cabinets are really stable and won’t start tilting or damage the wall over time.
My drywall sometimes has wooden studs behind it, but other times only metal studs with gypsum boards. I’m unsure how to best locate the fixing points or where to drill, whether special anchors are needed, and how to properly support the weight of the Metod cabinets.
The goal is to hang the cabinets so they hold firmly over time without the boards breaking out or the structure coming loose. Does anyone have concrete tips on which fasteners or anchors are best, especially regarding drywall with metal framing? Or experience with similar installations of Ikea Metod?
I look forward to your answers!
Hello lanofra,
I would like to go into more detail on the exact procedure to ensure optimal safety:
- Locating the studs: In the long term, it is worth investing in a high-quality multi-detector that can specifically detect metal thickness. Alternatively, you can carefully test by making a small drill hole (e.g., 2-3 mm (0.08-0.12 inches)) to check if you hit metal supports.
- Alternative mounting aid: If you are hanging multiple cabinets, you can attach a wooden batten (e.g., a roofing batten) directly to the studs and then hang the cabinets from it. This helps distribute the weight more evenly.
- Screws: For metal studs, self-tapping screws or sheet metal screws designed for thin metal profiles are particularly suitable. For wooden beams, use screws with a larger diameter and washers to increase load capacity.
- Weight consideration: A Metod tall cabinet weighs about 25 kg (55 lbs) empty, but filled with contents, it can easily weigh two to three times that. So plan for at least 50-75 kg (110-165 lbs) load per cabinet.
- Anchor type: Toggle anchors are useful if you only have drywall without directly accessible studs or wood. While they provide a better hold, they can fail under heavy loads.
My recommendation: Always try to secure to a load-bearing structure (wood or metal); toggle anchors should only be a last resort. Can you share a bit more about the wall thickness and the type of studs?
Good luck!
Good luck!
