ᐅ How can I securely fasten IKEA Metod kitchen cabinets during renovations?
Created on: 19 Jul 2015 09:37
Annasan
Hello everyone, I am currently planning a renovation of our kitchen and have chosen IKEA Metod kitchen cabinets. My main question is: How can I securely and stably mount these kitchen cabinets during a renovation, especially when the wall surfaces for mounting are uneven or made of different materials (e.g., drywall and brick)? Are there specific screws, fastening techniques, or installation methods that have proven effective with Metod cabinets to ensure the cabinets hang safely over the long term without damage from stress? I would appreciate detailed tips or experiences, ideally including advice on what to avoid.
Basically, a good spirit level is usually sufficient—especially for renovation projects. Additionally, you can use a laser level tool that projects a continuous horizontal line, which significantly simplifies the installation. This helps avoid errors caused by slightly uneven walls.
Regarding your questions:
- I know Lywatt screws as sturdy drywall screws, but for hanging large kitchen cabinets, I would still rely on special anchors that securely fill the cavity of the drywall panel.
- Connecting the cabinets to each other ensures that loads are better distributed and prevents the units from twisting relative to one another. So, this is more than just an option; it is an important contribution to overall safety.
If possible, I would always combine both methods.
Annasan schrieb:
What is the best way to measure the horizontal axis on slightly uneven walls? Is a simple spirit level enough, or would you recommend a more specialized method?I recommend using a long spirit level, especially if the wall is uneven, and checking several reference points. Additionally, wedge-shaped shims can be used for cabinet supports to compensate for any irregularities.
Annasan schrieb:
Do you think that in a standard kitchen, the connection between the cabinets significantly reduces the main load, or is it more of an optional safety feature?The connection helps distribute loads and prevents tipping movements, particularly with tall wall cabinets. I would consider it essential, especially if the wall is not consistently ideal.
A few practical tips that are often overlooked:
- Before installation, always pre-drill the cabinet brackets (Metod wall mounts) with an appropriate drill bit to prevent material cracking.
- If possible, do not fully tighten the screws at first; instead, tighten them lightly, hang the cabinet, and then fully secure them.
- When installing on drywall, it can be helpful to use multiple anchors along the length to better distribute the load.
- When adjusting, check not only for level alignment but also ensure the cabinets sit flush against each other.
This will help extend the overall durability.
bareynaldo20 Jul 2015 14:08Elisa schrieb:
Connecting cabinets to each other is always a good idea, yes.Admittedly, I consider that a given. But the question remains: What happens if the wall we’re supposedly relying on isn’t even straight? Aren’t these systems somewhat contradictory on their own?
Perhaps kitchen planners using Metod should really rethink the whole system and provide more flexible mounting options, not just rigid brackets. Stubborn walls require equally stubborn solutions.
