ᐅ How can I securely and discreetly fasten Malm furniture?
Created on: 24 Dec 2024 10:23
TILLTI
Hello everyone, I recently purchased some furniture from the IKEA Malm series, including dressers and nightstands, and I want to securely and discreetly fasten them to the wall. My goal is to prevent the furniture from tipping over if children or pets bump into them, without the fastenings being visually noticeable or damaging the furniture. Are there proven methods for safely securing Malm furniture, which materials or brackets work best, and how can visible drill holes or damage to the furniture be avoided? I would appreciate any tips, experiences, or recommendations for specific accessories you can suggest.
Palenar
24 Dec 2024 12:17
TILLTI schrieb:
Are there any tips on how to discreetly attach the brackets on the back or in the corners?
The topic of hidden fastening is definitely important. The Malm series has a thin back panel, which is not always suitable for screwing into because it can be easily damaged. My recommendation is the following approach:
- Drill the brackets into the inner upper edges of the side panels of the furniture, as these are more stable than the back panel. The brackets are usually barely visible there when the doors or drawers are closed.
- Choose brackets with a low profile, such as flat Z brackets or small L brackets. Often you can fix these with particularly small screws that go into the edges of the engineered wood.
- Additionally, you can apply clear nail polish to the screw heads or use small cover caps to visually conceal the spots.
- Also pay attention to careful positioning: the brackets should be placed as close as possible to the edges of the furniture sides, because further inside it is harder to keep them invisible.
Would you like me to provide examples of materials or sources?
TILLTI
24 Dec 2024 12:42
That would be great, I’m interested in sources. Which materials or suppliers do you use for angled brackets or invisible fasteners? And one more general question: How do you prepare to drill precisely without damaging the furniture due to drilling errors?
blapau
24 Dec 2024 13:03
For flat brackets and fasteners, I usually buy from well-known hardware stores like Obi or Hornbach, as they offer a wide selection and good advice. Online shops such as "tugumax.de" or "socketix.de" also provide suitable accessories specifically for furniture fixings.
Preparation: I recommend making a template from paper or cardboard that you hold against the edge of the furniture to mark the drill holes. This helps minimize drilling errors. It is also advisable to use a sharp wood drill bit at a low speed and to start with a pilot drill hole, meaning you first drill a smaller hole. This prevents the wood from splintering or tearing out.
A small tip: Applying tape over the drilling spot can hold the material better and reduces splintering when the drill bit enters.
Kinbu
25 Dec 2024 09:18
I would like to add that when securing Malm furniture, child safety should be the top priority. Therefore, in addition to fixing the furniture to the wall with brackets, it can be helpful to use optional anti-tip restraints, which are often installed underneath the furniture to prevent it from tipping forward.
TILLTI schrieb:
My goal is to make sure the furniture cannot fall over if children or pets bump into it
There are special furniture straps that can be installed without visible metal brackets – for example, fabric straps with metal components that are mounted inside the cabinet and anchored to the wall. These are discreet and definitely secure.
If you need tips on where to buy such straps, just let me know.
koduga
25 Dec 2024 10:05
I really appreciate how carefully safety for families is addressed here. I’ve personally experienced the stress of unstable furniture, which can really create an unsettling feeling.
I find those to be an interesting and practical alternative! Especially when, like me, you have an apartment where appearance is very important, such solutions are truly invaluable.
What does make me a bit uncertain, though, is whether small children might still be able to undo the straps if they are very clever. Has anyone had experience with this? Just so you know, TILLTI—you’re on the right track with your caution, and it shows how much you care about your family’s well-being. 🙂
TILLTI
25 Dec 2024 10:43
koduga schrieb:
What worries me a bit, though, is whether small children might still be able to undo the straps
That is exactly one of my concerns, as small children can sometimes be real experts at opening things that are not meant for them. That’s why I tend to prefer a mechanical solution with brackets combined with wall anchors. However, a combination of both might actually make sense.
Thanks to everyone for the tips so far. If anyone has further advice on handling or inconspicuous covers, I would be very grateful.
