Hello everyone, I have assembled several Malm furniture pieces, but I have noticed that they are often somewhat unstable, especially when I pull the drawers out multiple times or when I place heavier weights on them. My goal is to achieve a more stable installation of the furniture so that it twists or wobbles less. Does anyone have tips on how to make Malm furniture more stable during assembly? I would like to know which attachment points are particularly critical, whether additional fasteners are useful, and if certain screws or connectors should be replaced with sturdier versions. It would also be helpful if someone could point out possible weak spots during assembly. Thanks in advance!
Hello adamtu,
Thank you for your detailed question. MALM furniture is primarily designed for home use and not meant to withstand extreme loads, but with a few tricks, you can definitely improve its stability.
First, make sure to tighten all connections completely and securely without damaging the materials. Position all screws exactly as per the instructions. A common mistake is not properly securing the back panel: it acts as an important cross brace that prevents the furniture frame from twisting.
Second, you can replace the standard fittings with higher-quality connectors, such as stronger cam locks or wooden dowels with larger bearing surfaces. This often makes a noticeable difference.
Third, it can be worthwhile to occasionally attach additional brackets or metal plates on the inside corners, especially on taller dressers that tend to wobble.
If your drawers wobble when pulled out, the runners are often the issue. I have personally had good experiences with Blum drawer runners, which can sometimes be retrofitted on IKEA furniture.
Have you already identified which parts feel particularly unstable during your assembly?
Thanks in advance for the detailed advice, Ianlau.
So far, I have noticed that especially the feet or the points where they contact the floor are not always perfectly level and stable. Also, the side panels sometimes seem a bit loose, which is noticeable when pulling out the drawers. I installed the back panel, but I didn’t secure it very firmly because I was afraid of damaging the thin material.
You also mentioned retrofitting drawer slides – is there a particularly simple method to adapt them to an existing MALM furniture piece without much effort?
adamtu schrieb:
especially the feet or the points where they contact the floor are not always perfectly flat and stableThis is a common issue. Many MALM models have feet that are raised off the floor or have rather narrow contact areas. I recommend combining felt pads with slightly thicker plastic bases – this compensates for minor unevenness and provides better stability.
adamtu schrieb:
back panel not nailed very firmlyThe back panel is one of the most important components for stability! If you attach the thin back panel too loosely, it hardly acts as reinforcement. It’s best to use small nails or thin screws with the largest possible heads to secure the back panel firmly and without tension to the furniture. Lightly rubbing the surface before nailing can help prevent cracks.
Regarding the drawer slides: the original roller guides are not the most durable over time. It is often possible to convert them to simple metal slides with ball bearings, but you will need to slightly modify the sides of the drawers. Instructions can be found online by searching for “MALM drawer replacement with metal slides.” It requires a bit of DIY work, but it greatly improves smoothness in operation.
Here is a more structured guide for assembling the MALM furniture:
1. Preparation: First, check all individual parts for damage or warping. Warped panels can compromise stability.
2. Use of Wood Glue: Although not mentioned in the instructions, applying a small drop of wood glue at the joints can improve stability without making assembly harder.
3. Screws & Connectors: Use high-quality screws and avoid cheap ones. If possible, longer or thicker screws can be used to achieve better hold, as long as there is enough space.
4. Back Panel: Attach this carefully but firmly. Alternatively, you can retrofit back panels, for example, made from MDF boards that you cut and screw yourself.
5. Base Construction: MALM often comes with thin legs; I recommend installing small, height-adjustable furniture feet to optimize floor contact and compensate for minor unevenness.
6. Drawer Slides: Upgrading to metal slides like those from Blum significantly improves stability and ease of use.
If you want, I’m happy to provide tips on tools and an assembly workflow as well.
