ᐅ How can I secure IKEA Platsa furniture to prevent tipping in rental apartments?
Created on: 16 Mar 2020 19:18
Kisebastia
Kisebastia
16 Mar 2020 19:18
Hello everyone, I am looking for specific advice on how to reliably secure IKEA Platsa furniture, especially in rental apartments, to prevent tipping. I understand that most IKEA furniture, including Platsa, already comes with mounting kits, but in rental properties this is often more complicated due to building restrictions and possibly no permission to drill.
I am interested in solutions that are as reversible as possible, meaning they do not cause permanent damage to the walls, but are still secure enough to minimize the risk of tipping, especially with small children around. This can include innovative stabilization methods or specific product recommendations for additional safety measures.
Has anyone had experience with or without drilling and can assess if clamp or tension-based anchors are truly stable enough? Or are the usual wall panels and brackets indispensable? Please also share any insights regarding installation, safety, and everyday practicality. Thanks in advance!
NUGRANT
16 Mar 2020 20:02
Hey Kisebastia, this is a super important question, especially when there are children in the household! 🙂👍
I secured several Platsa cabinets with the original wall mounts, which come with special sets from IKEA. But if you’re not allowed to drill, try those adjustable tension rods that fit between the floor and ceiling! They’re really great because they work without any holes.
There are also special furniture anchors that you attach behind the cabinet and then clamp onto the frame of a door or window. This provides a lot of stability and leaves no marks.
Adhesive or magnetic solutions didn’t work for me, since the Platsa cabinets are made of relatively smooth wooden panels, and nothing sticks well to them. My tip: combine a tension rod with IKEA’s angle brackets if you’re allowed to drill at least into the wall—this holds super securely!
Don’t give up, safety comes first! 🚀
BLAKEO
17 Mar 2020 08:44
NUGRANT schrieb:
Try these adjustable tension rods that fit between floor and ceiling! They’re really clever because they work without any drilling.
That sounds good, but I see a potential issue: How stable are these tension rods against strong tipping forces, especially with heavily loaded shelf furniture? They rely solely on pressure, usually applied over a relatively small surface area. If a small force acts near the top, the leverage might cause them to fail.
Furthermore, it’s worth considering that rental apartments often have varying ceiling heights and floor coverings – so is this solution really universal?
It was also mentioned that adhesive solutions don’t hold well – here I would emphasize the importance of the material. Some self-adhesive furniture anchors are quite strong, but if mounted on porous wooden walls, they could indeed fail.
I would recommend, if drilling is allowed, to always opt for traditional wall fasteners. They have proven reliable and can often be removed easily after moving out. Otherwise, it really comes down to weighing risk versus security.
Kisebastia
17 Mar 2020 09:12
BLAKEO schrieb:
I would recommend, if drilling is allowed, to always rely on traditional wall mounting.
Thank you for your input! You bring up an important point about the option for removal: My landlord generally permits drilling as long as it is done properly and small holes are filled. Of course, I want to avoid causing any significant damage.
NUGRANT schrieb:
Adhesive or magnetic solutions were not an option for me because the Platsa furniture is partly made of fairly smooth wooden panels, which do not hold well.
That’s good to know. I thought there might be special adhesive kits for smooth surfaces, but if those don’t hold, it’s not very useful.
Additionally, I wonder if it would make sense for Platsa furniture to reinforce the individual sections by connecting them with joining hardware before securing them to the wall. Sort of an internal modular stiffening to reduce twisting and make tipping over more difficult. This would also be relevant if you need to move and want the furniture to stay connected.
Does anyone have experience with this?
DUVIN
17 Mar 2020 11:06
If drilling is allowed, use the IKEA wall brackets and connect the individual cabinet units with brackets or screws.
For rental apartments, this is the safest solution.
Clamp or tension fasteners are often not stable enough.
This makes the furniture much more secure, and you can also transport it easily when it is screwed together.
