ᐅ How can I secure Ikea Besta furniture to prevent tipping, especially in homes with children?
Created on: 30 Sep 2015 18:47
Nafudra
Nafudra
30 Sep 2015 18:47
I have a basic safety concern that mainly affects parents of young children: How do I secure Ikea Besta furniture against tipping, especially in households with toddlers?
I understand that tall shelves and cabinets always pose a potential risk when children climb on them or pull themselves up. This risk is particularly relevant for Besta units, which are often tall and narrow and can easily tip over.
I am interested in effective and practical measures you use or recommend to reliably secure these pieces of furniture against tipping without compromising their appearance or functionality.
I would appreciate tips related both to the structural anchoring (e.g., wall mounting, base modifications) and everyday solutions that families with children can use to reduce the risk.
Are there specific fixing materials or procedures that are ideal for Besta furniture?
Thank you in advance for your feedback!
barda6
1 Oct 2015 07:56
Nafudra schrieb:
How do I secure Ikea Besta furniture against tipping, especially in households with small children?
The safest method is always to attach the furniture to the wall using the supplied mounting brackets and anchors. Additionally, you can install kickboards at the bottom or store heavy items on the lower shelves to keep the center of gravity low. Important: Never place the furniture without wall anchoring.
Renla47
1 Oct 2015 14:33
Nafudra schrieb:
How can I secure Ikea Besta furniture against tipping, especially in households with toddlers?
Hello Nafudra,
I think your question is very important because furniture tipping unfortunately often leads to serious accidents involving children. Ikea Besta units, in particular, tend to be quite tall and narrow, which can affect their stability.
Here are some tips based on my experience and expert recommendations:
- Always use the wall anchors provided by the manufacturer. These are usually easy to install and prevent tipping.
- Whenever possible, position the Besta so that its longer side is against the wall, meaning the wider side is firmly supported.
- Avoid storing heavy items on the upper shelves. Keeping heavier loads lower lowers the center of gravity.
- Toddlers should not play unsupervised near standing shelves unless they are secured.
- Additionally, there are special anti-tip devices available that can be fixed either to the wall or to the floor.
- In daily life, it’s advisable to gently discourage climbing on furniture and to guide children playfully towards alternative climbing options (e.g., climbing frames).
If you like, I can also share some details about fastening materials or tips on drilling into walls.
Renla47
deoke
2 Oct 2015 22:11
Nafudra schrieb:
How can I secure Ikea Besta furniture against tipping, especially in households with young children?
This topic is extremely important, and I am happy to explain in detail:
1. Basically, using the supplied wall bracket with Besta is essential. These brackets are designed to permanently connect the furniture to the wall. Please note:
- The type of wall is crucial: For concrete or brick walls, use sturdy anchors (e.g., expansion anchors) and long screws.
- For drywall (plasterboard) walls, special cavity anchors or metal toggle bolts are required, as standard anchors will not hold.
- Always secure at least two brackets at the top of the furniture to ensure a stable connection.
2. Location: Position the Besta against a wall without radiators or power outlets to make drilling as straightforward as possible. The wall must be stable and load-bearing.
3. Load distribution: Arrange items so that heavy objects are stored in the lower compartments. This lowers the center of gravity and reduces the risk of tipping.
4. Additional measures:
- Floor adhesives or rubberized feet can reduce the furniture’s tendency to slide on smooth floors.
- You might also consider furniture risers with a wider base if your Besta units are very narrow.
5. Behavioral advice:
- Children should be consistently taught not to climb on furniture.
- Nevertheless, technical securing of furniture is mandatory, as relying solely on supervision or education does not reliably prevent all accidents.
Finally, two questions for you:
- What type of wall material do you have? This affects the fixing method.
- Are you planning a permanent installation or might you want to move the furniture later, which would complicate the fixing?
I am happy to assist you with a step-by-step guide to secure the furniture safely if you wish.
