ᐅ How do I repair Ikea HEMNES furniture after damage from moving?
Created on: 10 Apr 2023 08:17
Nimabu
Nimabu
10 Apr 2023 08:17
Hello everyone, I recently moved and some of my Ikea Hemnes furniture suffered minor to moderate damage—mainly scratches, scuffs, and a few small dents on the wooden parts. Since I want to keep the furniture in good condition and prefer not to replace everything, I’m looking for reliable methods to repair these damages. My specific question is: What is the best way to fix Ikea HEMNES furniture after moving damage? Which materials and tools are recommended, and are there any tips especially suitable for the types of wood and finishes used (mostly pine wood with lacquer or oil treatment)? I have no professional experience in furniture repair but want to do it myself as neatly and permanently as possible. Thanks in advance for your advice!
V
Vinlen
10 Apr 2023 09:26
Hello Nimabu, your concern is quite understandable. For HEMNES furniture, which is typically made of solid pine and usually treated with paint or oil, repairs are best done in several steps:
- First, treat small scratches with wax sticks or furniture repair waxes available at hardware stores.
- For larger dents, apply wood filler and then carefully sand it down.
- Afterwards, depending on the finish (paint or oil), recoat with special furniture paint or hardwax oil.
For oiled surfaces, it is important to choose oil matching the original (usually hardwax) to keep the appearance natural. If there is damage to joints, you should also check the screws and tighten or replace them if necessary. Tools such as fine sandpaper (grit 220 to 320) and wood filler are almost always needed.
bapar
10 Apr 2023 10:12
Vinlen schrieb:
For HEMNES furniture, which is typically made from solid pine and usually treated with lacquer or oil, repairs are best done in several steps:
This is the key point! You should proceed carefully with these pieces, as pine is relatively soft and can be easily damaged further. Here is a detailed process I recommend:
- First, clean the damaged areas with a soft cloth to remove dirt.
- For minor scratches, use color-matched wax sticks, then polish with a soft cloth.
- For deeper dents, you can gently raise the wood using a damp cloth and an iron: place the damp cloth over the dent and carefully apply the iron, which causes the wood to swell slightly and often helps.
- Next, carefully apply wood filler in a matching shade to any visible gaps or defects, smoothing off any excess material.
- After it dries, sand very finely (pay attention to the grain direction!) and finish with the appropriate lacquer or oil.
- Note: Test the oil or lacquer on a hidden spot first to see how your HEMNES furniture reacts.
One more important tip: document the condition before you start repairs – this is a helpful reference if you need to try multiple repair methods. Use your tools gently, and you’ll avoid causing additional damage.
noge58
10 Apr 2023 12:05
Great that you’ve already described it so precisely, Nimabu!
It’s also important: Don’t get discouraged if everything doesn’t look perfect right away! Repairing furniture is enjoyable and improves with each attempt.
I once had similar moving damage on my HEMNES dressers. A tip from me: after the repair, use a fine furniture polish for wooden furniture – it really freshens up the wood and also provides extra protection.
Additionally, my advice is to always apply small amounts of wax or filler and work carefully. This saves nerves and materials. Good luck, it’ll turn out fine!
Joe52
11 Apr 2023 07:58
That’s exactly it! When I was repairing my previously damaged HEMNES cabinets, I often felt like I wasn’t doing a good enough job. In some areas, the wood didn’t behave as expected, and I had to redo certain parts multiple times. But I realized that with patience, everything improves and looks better.
If you ever feel like something just isn’t working, take a break, let the furniture rest for a few days, and then try again. Often, this also helps mentally to continue working constructively.
Please share details about the exact nature of the damage — that helps us give more tailored advice.
bapar
11 Apr 2023 09:46
Joe52 schrieb:
Please give us details about the exact nature of the damage – that helps to tailor advice more effectively.
I agree with that. Even though you already mentioned that there are scratches, scuffs, and dents, it would be helpful to know the size of the affected areas or spots. For example, repairing narrow scratches is handled differently than addressing large surface damages or paint chipping.
Also, are the damaged furniture parts still stable or are they wobbly? The material can sometimes experience internal weakening after moving-related damage. I strongly recommend checking the joints before you start on the cosmetic repairs.
If you like, please also describe the surface treatment of your furniture (painted or oiled) – this makes it easier to suggest suitable products.
