ᐅ How can I repair chipped and damaged edges on IKEA Besta furniture?
Created on: 23 Jul 2019 07:46
silvio65
I have several IKEA Besta furniture pieces where the edges have chipped or been damaged over time. I would like to know the best way to repair these chipped and damaged edges so that the repairs are hardly noticeable afterward. I am especially interested in durable and relatively simple methods that can be done by oneself.
I have seen that some people achieve almost invisible repairs, while in other cases the edge remains visibly uneven or rough. Are there specific materials or tools that work particularly well for Besta?
Also, how should the edges be prepared before repairing to ensure good adhesion of the new surface? And does anyone have tips on the best repair material to use (putty, filler, edge banding, or paint)?
I’m looking forward to your tips and experiences, ideally with detailed instructions.
Thanks in advance!
benonon
23 Jul 2019 15:11
Certainly, here is a detailed step-by-step guide for repairing chipped and damaged edges on IKEA Besta furniture:
1. Preparation:
- Place the furniture piece in a well-lit, well-ventilated workspace.
- Carefully inspect the damaged areas.
- Gently sand the edges with fine sandpaper (220 grit) to remove loose laminate or splinters, aiming to make the edge as smooth as possible.
- Remove dust with a dry cloth, then clean the surface with a bit of denatured alcohol or isopropanol to eliminate grease or dirt.
2. Repairing the chips:
- Use wood filler suitable for chipboard or particleboard (preferably solvent-free and intended for furniture).
- Apply the filler thinly with a plastic spatula and smooth the shape with a damp sponge.
- Allow the filler to dry completely (follow the manufacturer’s instructions).
3. Sanding:
- After drying, smooth the repair area using fine sandpaper (240–320 grit), trying to restore the edge to its original shape.
4. Preparing and applying edging tape:
- Choose an edging tape that matches in color, thickness, and material (typical thickness for melamine surfaces is about 1 mm (0.04 inches)).
- Attach the tape using an iron set to medium heat with the steam function turned off, pressing the tape on evenly with steady pressure.
- Alternatively, use a hot air gun if the shape is irregular.
5. Trimming the edging tape:
- Cut off excess tape carefully with a sharp utility knife or an edging trimmer.
6. Fine sanding:
- Lightly sand the edges with 320 grit sandpaper to make transitions less noticeable.
7. Final treatment:
- Optionally, apply a thin layer of furniture polish or, even better, a special protective care film for added protection and appearance.
Tips:
- Take your time; this will make the repair look nearly new.
- For extensively damaged edges, it may be more cost-effective to order complete new side panels.
- Suitable edging tape is available at hardware stores or sometimes as accessories directly from IKEA.
If you would like any of these points explained in more detail, just ask.
Nicksin
23 Jul 2019 18:03
Hey silvio65 and all other DIY enthusiasts,
great topic! I always enjoy it when you can turn small imperfections into something beautiful again.
One small tip from me: When you iron on the edge banding, check with your fingers in between to make sure the adhesive is really sticking well – don’t let it get too hot, or you’ll get bubbles. The bonding feels best once the tape has cooled down.
I also find that gently rounding off the transitions by sanding really helps; it hides any sharp edges. Using a sanding sponge makes it easy to control the curve.
Go for it, it’s actually fun! 🙂
PS: Don’t get stuck on the details, that’s what makes a pro.
Karsten45
24 Jul 2019 07:39
Nicksin schrieb:
Just go for it, it’s actually fun! 🙂
I completely agree! Sometimes a small repair at home can be a cool mini workshop.
A little tip from me: If you wrap the sandpaper around a dry kitchen paper towel or a small piece of foam when sanding edges, you can apply more pressure and achieve smoother curves.
Another tip: For cleaning before the repair, use mainly alcohol or pure dishwashing detergent water, otherwise invisible grease can remain that will weaken the adhesive later.
Good luck, and let me know how it turned out for you!
Jonna
25 Jul 2019 09:18
In addition to the points already mentioned: When sanding both before and after applying the repair material, make sure the surface is as even and smooth as possible.
Also, when choosing filler for chipped areas, ensure it adheres well and does not come loose due to temperature or humidity changes. Epoxy or two-component wood fillers can be used, but they are only suitable to a limited extent for furniture with laminated surfaces, as the surface texture cannot be restored to match the original laminate design.
Functionality and appearance often involve a trade-off, so it is advisable to prioritize minimally invasive repairs using edge banding, provided there are no large chips.
