ᐅ How can I repair chipped and damaged edges on IKEA Besta furniture?
Created on: 23 Jul 2019 07:46
silvio65
silvio65
23 Jul 2019 07:46
I have several IKEA Besta furniture pieces where the edges have chipped or been damaged over time. I would like to know the best way to repair these chipped and damaged edges so that the repairs are hardly noticeable afterward. I am especially interested in durable and relatively simple methods that can be done by oneself.
I have seen that some people achieve almost invisible repairs, while in other cases the edge remains visibly uneven or rough. Are there specific materials or tools that work particularly well for Besta?
Also, how should the edges be prepared before repairing to ensure good adhesion of the new surface? And does anyone have tips on the best repair material to use (putty, filler, edge banding, or paint)?
I’m looking forward to your tips and experiences, ideally with detailed instructions.
Thanks in advance!
Hannes
23 Jul 2019 08:03
Hello silvio65,
It’s best to sand the edges first, then fill them with a wood-specific repair putty. After it dries, sand the area smooth and repaint it with suitable acrylic or acrylic enamel paint.
If the edge is severely damaged, applying a new edge banding with an iron-on method often helps.
gekira
23 Jul 2019 08:17
Hello silvio65,
for the precise repair of chipped edges on IKEA Besta furniture, I recommend the following steps:
- Thoroughly clean and degrease the edges to ensure adhesive and repair materials adhere properly
- Remove any loose or lifted laminate pieces
- Sand the area with fine-grit sandpaper (grit 180-220) to smooth the surface and prevent further peeling
- For small chips, use wood filler or putty applied with a spatula
- Once fully dry, sand the surface smoothly again with fine sandpaper
- Afterwards, either apply a suitable edge banding or, if paint is missing, use acrylic paint designed for furniture surfaces
It is important that the materials are compatible. IKEA typically uses melamine resin-coated particleboard with decorative laminate. Therefore, the edge banding should be self-adhesive and heat-resistant for ironing on, or the paint should be formulated for plastic surfaces.
Tools: fine sandpaper, spatula, optionally a heat gun (for edge banding), acrylic paint or edge banding, brush or roller for the paint.
I hope this answers some of your questions.
silvio65
23 Jul 2019 10:29
gekira schrieb:
It is important that the materials are compatible. IKEA mostly uses melamine resin impregnated particleboard with decorative foil.
Thank you, gekira, for the explanation. That matches my furniture exactly – it has a white decor with a melamine surface.
Is it really possible to apply such edge banding at home with a regular iron, or would it be better to use a heat gun?
And how can I make the transitions to the original frame as invisible as possible? Are there any tricks to prevent the new band from looking out of place?
benonon
23 Jul 2019 12:45
Hello silvio65,
I would like to address your questions about repairing the edges on IKEA Besta in more detail.
First: You can definitely apply edge banding with a regular iron. However, it is important that:
- The temperature should not be too high (usually around 120–150°C (250–300°F), depending on the manufacturer’s instructions for the edge band).
- Move the iron evenly and with consistent pressure over the tape to ensure good adhesion.
- Placing a thin cloth between the iron and the edge band protects against direct contact and prevents discoloration of the surface.
Alternatively, a hot air gun is more flexible if the edge is irregular.
Regarding the trimming:
- After applying the tape, you should cleanly cut off the adhesive edges with a sharp utility knife, blade knife, or a special edge band trimmer.
- Lightly sanding with fine sandpaper (grit 220–320) smooths the edges and makes them less noticeable.
- A perfectly matching color tone of the edge band is essential so it does not look like a foreign object.
Repainting afterwards only makes sense with uniform, paintable edge band types — the standard IKEA tape usually does not paint well since it is made of plastic.
If there are some small chips in the wood or chipboard core, I would fill the spots with acrylic or wood filler before applying the tape to create an even surface.
If you like, I can also provide you with a very detailed step-by-step guide to achieve the best possible results.
silvio65
23 Jul 2019 13:27
benonon schrieb:
If you want, I can write you a very detailed step-by-step guide to achieve the best possible results.
That would be great, benonon, I would be very grateful! It sounds like there are indeed some important details.
I really want to do the repair thoroughly because the furniture is placed together with my wall unit and should look good.
