ᐅ How can I repair broken glass doors from Ikea Metod myself?
Created on: 31 Aug 2022 08:14
Tipoke
Tipoke
31 Aug 2022 08:14
Hello everyone, I have a problem with a broken glass door on my Ikea Metod kitchen cabinet. Specifically, it is the glass front door that got a crack due to an accident, but it is still intact, meaning it hasn’t shattered or broken. My question is how I can repair or at least stabilize this door myself without having to buy a completely new door, which is quite expensive. Does anyone know a method or material to secure the crack, possibly with glue or a type of repair film? I would also like to know if the door can be removed easily without causing any damage, to make the repair easier. I appreciate any tips, especially if anyone has experience with Ikea Metod glass doors – how to remove them, which tools are needed, and how to safely reinstall them afterwards. Thanks in advance!
giabau
31 Aug 2022 09:27
Hello Tipoke, I have repaired a damaged Metod glass door myself before and can give you a few tips. First, about removing the door: Metod glass doors are usually attached with a clip system. For this, you need to:
- Carefully unhook the door by lifting the hinge lever with a screwdriver.
- Tip: Do not pull with force, or the glass may crack.
For repairing the crack:
- Use a clear adhesive based on epoxy or UV that is specially designed for glass. These adhesives can be applied with a small syringe.
- Alternatively, if you only want to stabilize it, you can use a transparent laminate film, which you stick on both sides of the door to prevent further cracking.
It is important to clean and degrease the surface well beforehand.
After the repair, let the door rest for several hours before hanging it back up.
If you are considering a complete replacement: Ikea often sells only complete doors, but it is worth checking directly with Ikea or looking for used doors in forums.
I hope this helps you!
SUFOJE
31 Aug 2022 10:43
Hello Tipoke, I can confirm that carefully removing the Metod glass doors is possible – it is important not to completely remove the hinges, but only to unlock the brackets. I would also like to add that working with glass always requires caution. If the glass has only a fine crack, I would definitely consider it to be permanently secure if you treat the crack with a suitable glass adhesive (epoxy resin or silicone glass adhesive).
In addition, you can improve stability by applying a thin transparent protective film. These films are also popular for window safety measures and prevent the glass from shattering if the crack worsens.
For cleaning the surface before bonding, it is best to use isopropanol to safely remove dirt and grease. After bonding, the adhesive should fully cure – the curing time is usually indicated on the packaging.
If you are unsure about the stability, I would rather replace the door, as safety is a priority in the kitchen area.
Ryder35
31 Aug 2022 11:08
Remove the door: lift the hinge pin using a screwdriver and take the door off. Fill the crack with UV adhesive and let it dry. If it’s not completely sealed, apply a foil over it. Done.
Joe52
1 Sep 2022 14:37
SUFOJE schrieb:
I would like to add that working with glass always requires caution.
This is really important. I’ve also had a glass pane shatter before, and only then do you realize how troublesome it can be. If you’re unsure whether the crack might worsen, I would recommend acting cautiously. With the Ikea Metod glass doors, I sometimes find it difficult to get the right replacement parts, which is more frustrating than helpful. However, some have managed to reinforce the door well using special adhesive – hats off to their patience!
I hope you find a solution that is both safe and practical for you.
Dirkmin
2 Sep 2022 07:52
The Metod glass doors are generally only available as complete units; IKEA does not offer replacement of individual glass panes. Therefore, using glass adhesive is the only practical DIY option for repairing a crack, provided it is not progressing further.
When using epoxy resin, the following should be observed:
- Glass surfaces must be absolutely clean and free of grease.
- The adhesive should be applied as thinly and evenly as possible.
- For optimal curing, UV curing is recommended if the adhesive supports it.
The door is subjected to low mechanical stress, so a properly executed bonding is usually sufficient to permanently stabilize the crack.
Be sure to consider the original furniture manufacturing during removal of the door, as careful handling is required to avoid damaging the hinges. Tools: small screwdriver, microfiber cloth, isopropanol for cleaning the glass surface.
