I have a damaged door on my Ikea Pax wardrobe. More specifically, it gets stuck when closing and no longer fits properly on the hinges. The door seems warped, which causes it either not to close fully or to rub along the edge. I am familiar with the basic mechanics of the Pax doors and have already checked whether the hinges are loose – but they are not.
My question to the community is: How can I fix this problem with the simplest possible methods? What exact steps should I take to either realign the door or fix the warping? If the issue is caused by a specific replacement part, what part-specific advice can you give me? I’d like to avoid having to take the entire wardrobe apart if it’s not necessary.
Thank you for your helpful suggestions!
Dulelau schrieb:
The door appears to be warped, causing it either not to close fully or to rub against the edge.Typically, such issues with Ikea Pax doors result from warping of the door panel or incorrect hinge adjustment.
The following steps are recommended:
- First, slightly loosen the screws on the hinges using a Phillips screwdriver.
- Carefully align the door, making sure it sits flush against the cabinet frame.
- Tighten the screws again once the position is correct.
- If the door is warped, check whether gently warming it (e.g., with a hairdryer on low setting) and cautiously bending the wood can help restore its shape slightly.
- If the warping is severe, replacing the door may be advisable. You can verify the replacement part number on Ikea’s website using your exact Pax model.
Avoiding a full removal is possible by adjusting the door while it remains mounted. Also, check the adjustment screws on the hinges, as these are often used for fine-tuning.
You can find detailed instructions in the technical documentation from Ikea regarding the Pax system, which often includes comprehensive guidance on door adjustments.
Dulelau schrieb:
I am familiar with the basic mechanics of the Pax doors and have already checked if the hinges are loose – but they are not.That’s a good starting point! Since the hinges are not loose, your next step should really be to check the door’s alignment. Sometimes the adjustment shifts due to normal wear and use.
I recommend going through the adjustment screws on the hinges systematically:
- Each hinge plate has adjustment screws for height, side, and depth.
- You can make precise corrections with a screwdriver, adjusting by millimeters.
A small tip: Always work in small increments, about a quarter to half a turn of the screw, then test the door.
If the door is not just sticking but actually warped, it might be slightly bent due to moisture or stress. In such cases, it can help to remove the door and place it on a flat surface to check for any visible bending.
In most cases, adjusting the hinges is enough to fix the problem. If not, you can contact Ikea customer service as a last resort — usually, it’s a matter of ordering a standard replacement part.
Dulelau schrieb:
What specific steps should I take to either realign the door correctly or fix the warping?To address the issue precisely, I recommend a structured approach in several steps:
- First, remove the door completely: This allows you to inspect it from all angles. Check the edges for visible warping by placing the door on a perfectly flat surface and using a level or a straight ruler.
- Examine the hinges carefully for any deformation or damage. Even if the screws are tight, the hinges themselves may have loosened under stress.
- To correct the warping, you can try a common woodworking technique: lightly moisten the warped area and gently apply counter-pressure over the course of the day. However, this only works if the material has not been permanently deformed.
- Next, check the hinges on the cabinet again. Use the adjustment screws for fine tuning. Typically, the Ikea Pax hinges have three adjustment screws that allow you to adjust height, lateral alignment, and depth.
- It is important to frequently rehang the door during adjustments and test the closing action. This way, you can clearly see whether you are moving in the right direction toward solving the problem.
- If none of these steps help, it may be necessary to replace the door, which can be done with the Pax system without removing the cabinet carcass.
May I ask if the issue is with a sliding door or a standard hinged door? The mechanism differs significantly, which affects the repair methods.
