ᐅ How can I remove scratches from IKEA Besta lacquer surfaces?
Created on: 6 Feb 2020 17:43
O
oswald69Hello everyone, I have a problem with my IKEA Besta furniture, specifically with the lacquered surfaces that I purchased about a year ago. Unfortunately, some scratches have appeared on the white, high-gloss lacquer finish, probably due to normal use or small moves. My question is: What are the best ways to remove these scratches effectively or at least minimize their appearance without damaging the lacquer or making the surface look dull? I have heard about car polishing kits, but I’m unsure if these are suitable for Besta finishes since it might not be a real paint layer but rather a foil or special laminate. If you have experience with IKEA lacquered surfaces, which products or methods have worked well for you? Thanks in advance for any helpful tips!
You can gently treat scratches on Besta lacquer surfaces with a fine polish. It’s best to use a plastic or furniture lacquer polish and apply it thinly. Important: do not use abrasive paste, as it is too harsh. Then, polish with a soft cloth in circular motions. If the scratch is deep, replacing the front panel is the only solution.
Hello oswald69, I understand your concerns well, so here is a more detailed assessment regarding Besta lacquer surfaces and scratches.
- First of all: The surface of IKEA Besta is usually a type of melamine resin or a thin lacquer foil, not a thick automotive paint layer. Therefore, it is sensitive to mechanical stress.
- Special furniture polish kits are suitable for superficial scratches, as they can fill and mask micro-scratches. For example, products containing carnauba wax or liquid plastic.
- Avoid abrasives and aggressive polishes. Even automotive rubbing compounds can be too harsh.
- For light scratches, you can also use furniture repair markers that match the color precisely.
- For deeper damage, it is often best to replace only the affected panel, as repairs can quickly look uneven otherwise.
Regarding the procedure:
1. Clean the surface thoroughly first, making sure there is no residue.
2. Test on a small area.
3. Apply the product with a soft cloth and a small amount of polish.
4. Buff and allow to dry.
I recommend paying close attention to the manufacturer’s instructions. If you like, I can also provide some specific product recommendations.
KODAN32 schrieb:
For light surface scratches, special furniture polish kits work well, as they can fill and conceal micro-scratches. For example, products containing carnauba wax or liquid plastic.Exactly! And remember, always be gentle. The Besta finish is delicate, so it’s better to leave abrasive pastes on the hardware store shelf 😉. A little tip from me: take a coffee break now and then— polishing is easiest when you’re relaxed!
Hello oswald69, I would like to revisit the post from KODAN32 and add some technical details that are important when trying to remove scratches from IKEA Besta lacquered surfaces.
The surface of Besta is in most cases a UV-cured melamine foil, which is very thin and hardly tolerates any mechanical stress. Therefore:
- Mechanical sanding is usually not an option because it immediately exposes the underlying substrate layer.
- Polishing compounds should definitely contain no abrasives but act as softeners or fillers for micro-defects.
- Liquid carnauba wax-based products are ideal as they fill scratches and preserve the gloss.
A step-by-step suggestion:
1. Clean the surface thoroughly with a mild dishwashing detergent and a soft, lint-free cloth to avoid dirt particles causing scratches.
2. Dab some polish containing carnauba wax (e.g., wax-based furniture care) onto a soft microfiber cloth.
3. Gently and evenly rub the polish into the scratched area using circular motions.
4. After a few minutes, buff again with another clean cloth.
5. For deep scratches, this is the limit—replacement of the front panel is recommended.
Finally, an important question for you: How deep are the scratches? Are they only visible, or can you feel them with your fingernail? Depending on the depth, the approach can be adjusted.
