ᐅ How do I remove adhesive residue from Malm furniture?
Created on: 2 Jul 2022 08:43
prachen
prachen
2 Jul 2022 08:43
I recently purchased some Malm furniture from Ikea and unfortunately found adhesive residues left behind after removing protective films or price labels. These sticky residues cling quite stubbornly to the surface, and I want to avoid damaging the furniture by using the wrong cleaning agents or physical removal methods.
My question is: What methods or products work best to remove adhesive residues from Malm furniture without scratching, dissolving, or discoloring the surface? Are there any specific products that have proven effective, or gentle home remedies that are both safe and efficient? A step-by-step guide would be very helpful, if possible.
I look forward to your tips and experiences!
boelnu
2 Jul 2022 09:58
I have often had the same problem with Malm furniture myself and know how frustrating it can be.
What has always worked quite well for me is to first gently soak the area with warm water and a soft cloth to soften the adhesive a bit. After that, I used a common adhesive remover eraser – a small rubber block that you can specifically find for glue residues in craft stores. This usually allows you to remove the adhesive effectively and, most importantly, without causing any damage.
prachen schrieb:
Which methods or products are best suited to remove glue residues from Malm furniture without scratching, dissolving, or discoloring the surface?
Maybe this is a gentle alternative to chemical products. It’s important that you definitely don’t use harsh scrubbing pads or sharp tools – that causes more damage than it helps. :-)
Have you tried any products already?
TEBILO
3 Jul 2022 14:26
To remove adhesive residues from Malm furniture, the following points should be considered to ensure both effectiveness and surface protection:
1. Check the surface material: Malm furniture usually has a slightly melamine resin-coated surface. This is relatively durable but sensitive to strong solvents like acetone or nail polish remover.
2. Step-by-step cleaning:
- Start with mild substances, for example, warm water with a little dish soap.
- If needed, apply some isopropyl alcohol (70%) to a lint-free cloth and rub gently.
- Use mechanical action only with soft materials, such as a plastic scraper.
3. Oil-based adhesive residues
- For sticky, oily residues, a special adhesive remover designed for sensitive surfaces can be used. These products are generally low-odor and acetone-free.
4. Simple home remedy tip:
- Put a few drops of olive oil or baby oil on a cloth and gently loosen the adhesive, then wipe clean with a mild cleaner.
5. Important: After each treatment with solvents or oils, thoroughly clean the surface to remove residues that can attract dust.
Before you start, I recommend testing a small, inconspicuous area. If you tell me whether the adhesive residues are rather dry and hard or sticky, I can suggest the next appropriate step.
boelnu schrieb:
Der Kleberadierer ist eine schonende Alternative zu chemischen Mitteln.
I agree, combined with the oils mentioned, this can be very effective.
SAWYERR
4 Jul 2022 10:17
No effort required:
1. Apply warm water and dish soap.
2. Put a small amount of baby oil on the adhesive and let it sit briefly.
3. Wipe off with a soft cloth.
4. For any residue, gently use a plastic scraper.
Do not use harsh solvents or metal scrapers.
