Hello everyone, I am currently planning my new living room wall with IKEA Billy shelves and have encountered a recurring issue: the shelves tend to sag or warp under heavy or uneven loads. I want to protect my BILLY shelves from such deformation as effectively as possible without installing expensive reinforcements or making major changes to the furniture.
Does anyone have practical tips or tricks to keep the shelves more stable overall? • Are there any recommended additional material reinforcements? • How important is the maximum load per shelf? • Or do certain support techniques help?
I would appreciate your experience and recommendations so I don’t have to replace my BILLY shelves again after a short time.
Hello Jordan56!
I am very familiar with this issue – the BILLY shelves made of particleboard need to be handled carefully, or they will sag quickly. My best advice is to place thin wooden or metal strips underneath the center of the board, attaching them discreetly. This relieves stress from the middle of the shelf and prevents it from warping easily.
That’s exactly the point! But be careful: don’t overload the shelves. IKEA states a maximum of 30 kilograms (66 pounds) per shelf. If you’re storing heavy items, it’s better to distribute them over several shelves or add supports.
Another idea I find interesting is reinforcing the shelves with special veneer strips or thin steel strips – that lasts a very long time. If you’re handy, this is something you can easily do yourself.
Good luck with building your shelving! 🙂
Jordan56 schrieb:
The shelves tend to sag or deform under heavy or uneven loads.
Hello Jordan56, I completely understand your concern, as the relatively thin BILLY shelves often bend under load. My recommendation goes in two directions: First, avoiding point loads helps distribute the weight more evenly. Always place heavy books or items so that they rest on both sides of the middle section or are spread across several shelves.
Second, I like to use additional supports made from wooden strips, which can be either glued or screwed to the underside of the shelves. This noticeably increases the load-bearing capacity.
I agree, such strips are a simple and effective solution. If you want to avoid visible screws, wood glue and small nails that can be filled later also work well.
I hope this helps. If you want, I can also tell you where to get the appropriate strips.
Elodie schrieb:
Place thin wooden or metal strips under the middle of the shelf, which you attach inconspicuously.
I believe the load capacity of the BILLY shelves must be considered in relation to their material quality. Particleboard has its limits. This brings the following important points into play:
1. Maximum load: Ikea usually specifies 30 kg per shelf, but this applies under optimal conditions – meaning evenly distributed weight and regular, not permanently heavy loads.
2. Reinforcements are worthwhile only if the loaded weight is frequently and continuously placed at the same spot.
3. Another idea: Instead of just reinforcing the shelves from below, you can proactively replace them with stronger panels (e.g., 19 mm (3/4 inch) plywood) in areas with high load.
That is true, but in my opinion, it is a cosmetic and more expensive solution that only partially solves the problem.
I would carefully analyze the loading and the type of use and consider whether a sturdy compartment with an additional center support might yield better results.
Espen schrieb:
Reinforcement with aluminum profiles helps.
