ᐅ How can I protect Ikea Pax wardrobes from pet damage?
Created on: 28 Nov 2021 08:13
Deo35
Hello everyone, I have a specific question and could use your expertise: How can I protect my Ikea Pax from pet damage?
I have two cats who are very curious and like to scratch furniture or sometimes play with their claws on doors and cabinet components. The Pax is quite expensive and unfortunately already shows some signs of this “affection.”
My question is how to make the Pax more resistant both visually and functionally without having to buy new furniture. What has worked well for you? Are there materials, protective films, or tricks that are especially suitable for the surface and construction of the Ikea Pax?
I appreciate practical tips that are truly effective for everyday use.
Jodyro
28 Nov 2021 10:11
Quick tip: Self-adhesive plastic furniture protective pads. Simply cut to size and stick on. Cats usually stop scratching there afterward.
GU-LAU60
28 Nov 2021 10:26
I also recommend securing the cabinet doors to prevent them from wobbling or rattling, as this can attract pets. Additionally, upholstery fabrics reinforced with nylon are more durable, but this is difficult to implement with Pax.
Gregory
28 Nov 2021 11:02
The Ikea Pax is primarily made from particleboard with a melamine coating, which is not very resistant to mechanical stress.
For long-lasting protection, I recommend the following measures:
- Applying transparent scratch protection films with high abrasion resistance (these can be applied to doors, side panels, and fronts).
- Using plastic edge protectors on exposed areas.
- Reinforcing door handles and built-in components with harder materials.
Behaviorally, you should also try to distract cats from the furniture by providing appropriate scratching posts or furniture.
Deo35
29 Nov 2021 07:56
Gregory schrieb:
The Ikea Pax wardrobe is primarily made from particleboard with a melamine coating, which is not very resistant to mechanical stress.
Thank you for the detailed explanation. That really clarifies the vulnerability.
I had considered attaching a thin plexiglass panel (with spacer mounting) to the sides, but that would probably look rather unattractive quite quickly.
Are there any alternatives that are less visually intrusive? My cats also often scratch the door, and I’m afraid the paint will peel off completely otherwise.
Karsten45
29 Nov 2021 08:19
Deo35 schrieb:
Are there alternatives that are less visually obtrusive?
Using a plexiglass panel sounds like a practical idea at first, but yes, you’re right, it usually looks like a beer crate mounted on the wall 😅.
We’ve had good experiences with clear self-adhesive protective films – they’re very thin, almost invisible, yet still durable.
Also, if you set up designated scratching areas for the cats (like scratching posts) nearby, the furniture is often spared. Sometimes a bit of catnip helps to attract them away from the wardrobe.
faso31
29 Nov 2021 08:48
Karsten45 schrieb:
If you build specific claw zones for cats (like playboards) nearby, the furniture is often already protected.
Providing a distraction is certainly helpful, but how lasting is it? In my experience, cats tend to ignore designated options if the furniture is easily accessible.
It would be interesting to hear if anyone here has any long-term observations on which protective measures truly preserve the Pax sustainably.
