ᐅ How do I correctly install Ikea Pax hinges?
Created on: 4 Oct 2021 14:23
Jimlo
Jimlo
4 Oct 2021 14:23
I bought an Ikea Pax wardrobe and am now facing the challenge of attaching the hinges to the doors correctly. Since I rely on precise installation, I want to ensure that the doors not only hang straight but also open and close smoothly and quietly.
My specific question is: How do I properly install Ikea Pax hinges so that the door is perfectly aligned and does not become misadjusted over time? Which screws should I use, how should the hinges be mounted, and are there any small tips or common mistakes I should definitely avoid?
I look forward to detailed and comprehensive advice so I can carry out the installation professionally and successfully. Thanks in advance!
PLOMA
4 Oct 2021 18:37
Hello Jimlo,
regarding your question about how to properly install the Ikea Pax hinges, I would like to provide you with a detailed step-by-step guide that I have developed over time. The hinges on Pax units are typically cup hinges (also known as concealed hinges) and require special care during installation.
- First, you should check whether the supplied screws are indeed the correct ones. Ikea usually uses flat-head screws with a Phillips drive – these are sufficient, but you should ensure they are tightened securely, otherwise the hinge will be loose.
- The hole for the hinge cup on the door panel is usually pre-drilled. If not, a special hole saw with a diameter of 35mm (1.38 inches) is required for the cup holes. The depth is also important; it usually needs to be around 12–13mm (0.5 inches) so that the hinge sits flush.
- When attaching the hinge to the door, you should first screw it in loosely so that you can adjust the rear adjustment screw. Fine-tuning here is crucial.
- The hinge is also attached to the cabinet carcass, again first loosely. The double adjustability (side to side and in depth) allows perfect alignment of the door after installation.
- A common mistake is over-tightening the screws, which can damage the cabinet or cause the hinge to become loose.
- It is best to use a cordless drill with torque control to avoid damaging the screws or the furniture.
- After fastening, test the opening and closing several times to fine-tune the adjustment screws on the hinge. You can also adjust the alignment of the doors to each other at this stage.
A question for the group: Jimlo, how has your experience been so far with furniture assembly? Do you have any specialized tools available? Then I can give you even more precise advice.
LAURE-TA
5 Oct 2021 09:42
PLOMA schrieb:
When attaching the hinge to the door, you should first screw the hinge on loosely so you can adjust the rear adjustment wheel.
This is a very important point that I can fully agree with.
For clear structure:
- First, check whether your doors and the cabinet frame are really flat and even. Any irregularities here will make later adjustments much more difficult.
- Initially, mount the hinge loosely on the door. The screws on the mounting plate, which is attached to the cabinet frame, should also be only hand-tightened.
- Now hang the door and check the gaps at the top, bottom, and sides. Ikea Pax hinges usually offer three adjustment options:
- lateral adjustment
- height adjustment
- depth adjustment
- Use the adjustment screws on the hinges to align the door as parallel to the cabinet frame as possible. Also check the gap between the door and the cabinet side panel here.
- Make sure the hinge screws attaching the hinges to both the cabinet frame and the door leaf are tightened adequately without overtightening to avoid damaging the wood.
- For wooden doors: avoid placing screws directly next to each other, as this can weaken the material.
- If your door still sticks after adjusting, check whether the hinges might need lubrication – a light drop of silicone spray can help.
Summary:
1. Screw hinges in only hand-tight at first.
2. Hang the door and check the gaps.
3. Use the adjustment screws for alignment.
4. Tighten the screws securely.
5. Perform a functionality test.
If you want, I can also prepare a simple guide for adjusting the various adjustment screws.
relupa
6 Oct 2021 11:08
Jimlo schrieb:
Which screws should I use, how should the hinges be installed, and are there any small tips or mistakes I should definitely avoid?
I understand how stressful such an installation can be, especially when you want everything to work perfectly.
I also had issues with the Ikea Pax hinges because I tightened the screws too much, which damaged the wood. After that, I learned to tighten the screws by hand first and then adjust them afterwards. That helped a lot.
Another tip I can give is to take your time with the fine adjustment and don’t get discouraged if it doesn’t work perfectly right away. Sometimes it helps to remove the door several times and adjust the hinges again.
Your question definitely makes sense and shows that you care about doing a proper job. If you want, I can share more about my experiences with similar situations. Just ask.
