ᐅ How do I properly mount Ikea Metod wall cabinets on concrete walls?
Created on: 3 Sep 2020 08:23
Sintalat
Hello everyone, I am currently planning to install Ikea Metod wall cabinets in my apartment. The walls are made of concrete, and I’m wondering what the best and safest way is to mount the cabinets.
Specifically, I’m interested in:
- Which types of anchors and screws are recommended?
- Are there any special considerations for concrete, such as drilling techniques or load distribution?
- Does anyone have experience specifically with Metod cabinets and concrete walls?
I would appreciate any tips and recommendations, as I want to work as safely and durably as possible and avoid doing a half-hearted job.
Thank you for the answers so far! One important question remains: Can I use a regular hammer drill to drill directly into the wall, or is a rotary hammer absolutely necessary for a clean and secure installation of the Ikea Metod wall cabinets? I only have a regular hammer drill, not a rotary hammer. Or do I possibly need special accessories to drill the holes deep and precisely?
JAMESONB414 Sep 2020 08:52Sintalat schrieb:
Can I also drill directly into the wall with a regular hammer drill, or is a rotary hammer absolutely necessary for a clean, secure installation of the Ikea Metod wall cabinets?A rotary hammer is definitely better for concrete. It makes the work easier and ensures precise holes. Using a regular hammer drill takes longer and the drilling may be less accurate.JAMESONB41 schrieb:
A rotary hammer is definitely better for concrete. I can confirm this from personal experience. I used a regular hammer drill, but it really required a lot of strength and affected accuracy. For one or two holes, it might be manageable, but with several, it quickly becomes tiring and hard to control.
Maybe you can borrow a rotary hammer for this task.
In addition to the tools: Use high-quality concrete drill bits that are sharp. A dull bit generates more dust and produces inaccurate holes, which reduces the holding strength of the anchors.
Another useful tip: After drilling, thoroughly clean the holes with a vacuum cleaner or compressed air. As mentioned before, anchors should not just be inserted but also carefully set to ensure they expand properly inside the concrete.
One more tip: Ikea Metod wall cabinets often have relatively narrow mounting points. Therefore, double-check that the screws and anchors are not too wide, or you might face difficulties with the holes.
