ᐅ How can I securely fix IKEA Metod kitchen cabinets to concrete walls?
Created on: 27 Oct 2022 18:03
dragoljub
dragoljub
27 Oct 2022 18:03
Hello everyone, I am currently planning to install IKEA Metod kitchen cabinets in my new apartment. Unfortunately, all the walls are made of solid concrete. Now I am wondering how to securely and optimally fasten the wall cabinets to these concrete walls so that they hold up long-term and there is no risk of accidents. Which types of anchors or screws are best suited for this type of wall, and are there any special tips regarding pre-drilling or other particular aspects I should consider during installation? I would greatly appreciate any experiences or recommendations, as I plan to do the installation myself and want to be absolutely sure.
Joe52
27 Oct 2022 18:27
Hello dragoljub, this is an important question, especially for heavy kitchen furniture like Metod, to ensure long-term safety. I once had problems with anchors that were too weak in concrete, which was very frustrating. It is important to use high-quality concrete anchors, preferably expansion anchors or metal anchors designed for concrete. Additionally, you need to drill very carefully, ideally with a hammer drill or rotary hammer, so that the hole is clean and the right size. I would recommend investing a bit more time in preparation, as it pays off in the end.
Jorgela
27 Oct 2022 18:45
It is best to drill standard concrete holes with an 8 mm (5/16 inch) hammer drill bit and use 8 mm (5/16 inch) metal expansion anchors. Then secure them with 6 mm (1/4 inch) screws; this is sufficient for concrete.
Nakar33
27 Oct 2022 19:12
Hello dragoljub, mounting IKEA Metod wall cabinets to a concrete wall requires precise execution. First, you should determine the weight of each cabinet to choose anchors with the appropriate load capacity. I recommend using either high-quality metal anchors that expand within the drilled holes or chemical resin anchors, which can support significantly higher loads. In unfavorable cases, standard plastic expansion anchors may pull out, especially in porous or deteriorated concrete. Pre-drilling should be done with a rotary hammer and a concrete drill bit of the correct diameter, slightly deeper than the anchor length to ensure a secure hold. Make sure to remove dust from the drill hole thoroughly, ideally with compressed air or a brush, to achieve the best possible grip. Also, pay attention to the alignment of the wall cabinets to minimize stress later on.
dosogau
27 Oct 2022 19:27
Metal anchors or heavy-duty anchors are the best choice. Do not forget to pre-drill accurately with a rotary hammer.
sobau
27 Oct 2022 19:55
Hammer drill 8mm (0.3 inches), metal expansion anchors, 6mm (0.2 inches) screws, that fits well.
