ᐅ How do I securely mount Ikea Metod wall cabinets to solid walls?
Created on: 6 Feb 2020 09:12
annica47
I am currently planning to install several Ikea Metod wall cabinets in my kitchen on solid walls and want to ensure that the mounting is really stable and secure. The walls are made of solid concrete with plaster. I am especially interested in which anchors and screws you would recommend to guarantee a reliable attachment—particularly concerning load capacity without damaging the walls or risking the cabinets falling down eventually.
Additionally, it would be important for me to know if you have any tips on wall preparation or the correct way to mount directly onto the wall. What would be the best approach, for example, regarding sealing or positioning?
Thank you in advance for your expert experience and recommendations!
TARAON
6 Feb 2020 13:15
Oh, this all sounds very technical, but don’t worry 😊! I also found installing the Metod cabinet units on my concrete wall a bit intimidating at first, but with the right tools, it’s easy. A hammer drill is definitely helpful, as it makes drilling cleaner and simpler. My tip: Rent one from the local supplier—it’s worth the 10 euros.
Regarding chemical anchors: They are fantastic when you need maximum load capacity. They practically bond everything together solidly and hold like a rock, which gives you peace of mind with heavy cabinets! Just be patient—allow at least 24 hours curing time unless you use a fast-curing version and need it done quickly.
And don’t worry, you’ve got this! Then nothing will be out of place 😉.
janfo
6 Feb 2020 13:37
It is worth renting a hammer drill. Using a rotary hammer drill can be difficult with solid concrete. Chemical anchors provide better support for heavy loads. The drill hole must be clean.
NUGRANT
6 Feb 2020 14:09
annica47 schrieb:
How powerful should the drill be? I only have a rotary hammer drill; is that enough, or should I rent a rotary hammer drill?
A rotary hammer drill is definitely better, but not absolutely necessary if the concrete isn’t extremely hard. I’d try your rotary hammer drill first, but if drilling becomes difficult, be sure to rent a rotary hammer drill somewhere!
annica47 schrieb:
Is it worth the effort? And how long does the curing take before you can load it?
Chemical anchors might seem complicated, but they offer excellent hold! The curing time is 10–24 hours depending on the material – but for maximum safety, this is the best choice! Good luck!
Gilbert
7 Feb 2020 08:42
I often hear people mention “heavy-duty anchors, chemical anchors,” but honestly: how crucial is the mounting method for Ikea Metod wall cabinets? These cabinets aren’t meant to last forever, more for rental apartments anyway. A few inexpensive plastic anchors and screws from a hardware store are usually enough, unless you’re planning to hang flagpoles or something heavy.
I dare say most people replace or redecorate their wall cabinets after a few years – so why go to such lengths? You can achieve the same result with simple solutions, and if something does fall, is it really that dramatic? I think this concern is often exaggerated.
JAFUHAU
7 Feb 2020 10:11
I understand that safety and stability are important, but Gilbert also makes a valid point: not every situation requires the heaviest and most expensive solution. What matters most is assessing your own effort and the condition of the wall.
It might help to choose a larger number of fixing points, which distributes the load more evenly and reduces the risk of failure. Additionally, a steady hand during installation is crucial.
If you’re unsure, my advice is to drill one hole too many rather than risk damage later. Balance and common sense go a long way.
annica47
7 Feb 2020 14:55
Gilbert schrieb:
I dare say most people replace or redecorate wall cabinets after a few years – so why put in so much effort?
I believe this is not a valid reason for sloppy mounting. Especially in rental apartments, you want everything to be securely and firmly fixed in place, otherwise it can lead to trouble and, in the worst case, accidents.
My concern is how to mount IKEA Metod wall cabinets as safely, permanently, and professionally as possible on truly solid concrete walls. While I find the discussion about materials and effort interesting, my main focus is on secure fastening methods and the best anchors and screws for concrete with plaster.
Thanks also to everyone who has already provided helpful tips on drilling and installation!
