ᐅ How do I properly assemble IKEA Metod cabinets with soft-close doors?
Created on: 7 Jul 2021 14:23
LUGUPO
I am currently planning to assemble IKEA Metod kitchen cabinets with soft-close doors and have several questions regarding proper installation. In particular, I am interested in how to correctly adjust the hinges on the soft-close doors so that they not only close smoothly but also function reliably over time. I am also wondering if there are any specific recommendations about the order of assembly—for example, whether the cabinet carcasses should be fully assembled before attaching the doors, or if it is better to do this simultaneously. I have the instructions on hand, but I find the details on the soft-close mechanisms and precise adjustments to be quite brief.
Does anyone have experience with the accurate assembly of these cabinets and tips on how to avoid mistakes? Are there any tricks to ensure the doors are aligned evenly? I would really appreciate a detailed explanation, as I want to avoid any errors as much as possible. Thanks in advance!
Guyju
8 Jul 2021 12:00
A few final notes:
- After installing the doors, regularly check the hinges, as they might slightly loosen due to minor movements when closing.
- If you frequently need to adjust, remember that the coordination between depth and lateral adjustment is crucial. Start with horizontal alignment, then depth, and finally height.
- Regularly cleaning the dampers with a dry cloth helps prevent dirt buildup that can interfere with the soft-close mechanism.
- If the doors do not close properly despite optimal adjustment, the hinge type might be the issue. IKEA offers different versions depending on the weight and size of the door.
I hope these tips help make your project a complete success.
