ᐅ How can I creatively customize IKEA BESTA doors with colors and patterns?
Created on: 23 Jun 2022 09:17
Chenpo43
Chenpo43
23 Jun 2022 09:17
Hello everyone, I recently purchased some IKEA BESTÅ units and now want to creatively design the doors. I am especially interested in how to work with paint and patterns to create truly unique and appealing surfaces. I am considering various techniques, such as painting with acrylic paints, applying stencil patterns, or even using wallpaper as a covering. Are there any tips on suitable paints or specific methods that work particularly well for the plastic or wood fiber boards of the BESTÅ doors? Additionally, it would be great if anyone has experience with the durability and ease of cleaning of such customizations. How can one avoid issues like visible wear or paint peeling? Thanks in advance for your opinions and advice!
plopra
23 Jun 2022 09:45
Acrylic paints work best on well-sanded doors, followed by a clear varnish. For patterns, simply use stencils and a sponge. Important: Clean the surface thoroughly and lightly sand it beforehand; this helps ensure better adhesion.
Tevin
23 Jun 2022 10:22
Hello Chenpo43, your question is very well formulated and shows that you have already looked into the materials a bit. Regarding your question: For the BESTÅ doors, you should note that some variants have a smooth lacquered surface, while others are more melamine-coated. For smooth lacquered surfaces, acrylic paint works very well in combination with fine sandpaper for preparation, followed by a clear coat for protection. For melamine-coated doors, you can also use special plastic paints or even vinyl films as alternatives. Stencils are ideal if you want clean edges; otherwise, freehand patterns are also nice but require practice. Regarding durability: Clear coats protect wonderfully against wear; it’s best to use matte or satin finishes, as they are less prone to scratches. Additionally, when cleaning, you should use mild products to avoid paint chipping. If you like, I can also provide you with a step-by-step guide.
Garry
23 Jun 2022 11:05
I would like to add that surface preparation is the key factor for success. The doors from BESTÅ are mostly made of particleboard with a painted or melamine-coated surface. Sanding can help improve adhesion on painted doors, but sanding melamine surfaces is difficult. In this case, a primer for plastics or even a special adhesion promoter is recommended. Patterns work particularly well when created with acrylic or chalk paints, as these provide good coverage and allow for different textures. Another tip: for especially durable results, applying two to three coats of clear varnish at the end can be beneficial. However, it is important to ensure that the varnish is compatible with the substrate to avoid cracking.
Chenpo43
23 Jun 2022 12:45
Thank you for the detailed answers so far! @Tevin, a step-by-step guide would be really helpful, especially since I'm still unsure about the best way to prepare the surface for painting. I have some doors with melamine and others made from a type of painted wood fiberboard. Are there differences in priming for these materials, or can I use the same method? Also, what should I consider when choosing paint to ensure it is durable and somewhat scratch-resistant? Additionally, I’m interested to know if anyone has used stencils or patterns to cover larger areas and whether it works better vertically or horizontally.
Tevin
23 Jun 2022 13:31
Sure, here is a brief step-by-step guide for the doors:
- Cleaning: Clean all doors with a degreasing cleaner, such as a mild dish soap, to remove dust, grease, and dirt.
- Sanding: Lightly sand doors with a melamine surface using very fine sandpaper (around 240 grit). Be careful not to sand too hard to avoid scratching the surface.
- Primer: For melamine, it is best to use an adhesion primer specifically designed for plastics. For painted wood fiberboard, a standard acrylic primer can be used.
- Observe drying times!
- Paint application: Acrylic paints are flexible and suitable. Apply thin layers and allow each to dry thoroughly.
- Patterns & stencils: Plastic stencils are recommended for clean edges. Vertical or horizontal patterns depend on preference—vertical stripes often appear calmer, while horizontal ones make surfaces look wider.
- Finish: Apply a clear coat, ideally matte or satin finish.
Scratch resistance is mainly achieved through the clear coat and paint layers. Use high-quality products to ensure the paint lasts well during cleaning.
