ᐅ How can I optimize the lighting inside IKEA Metod tall cabinets for better visibility?
Created on: 6 Sep 2024 08:23
ridutar
ridutar
6 Sep 2024 08:23
Good morning everyone,
I am currently facing the challenge of optimizing the lighting in my IKEA Metod tall cabinets to get a better overview of their contents. Since these tall cabinets are often quite deep and high, it is difficult to have sufficient light in the back areas, especially when the door is closed or the room lighting is low.
Specifically, I am interested in:
- Which types of lighting work best (LED strips, spotlights, light bars)?
- How can I achieve as even illumination as possible across the entire cabinet height?
- Are battery-powered or wired solutions better suited in the long term?
- Are there recommended installation methods that work well with IKEA Metod tall cabinets without damaging the furniture?
I already have some ideas but would like practical, proven advice to avoid unnecessary purchases and a lot of trial and error. Thanks in advance for your help!
Jensson
6 Sep 2024 09:42
Hello ridutar,
I can understand your question well, as lighting in deep cabinets is indeed a challenge. Here are some recommendations that might help you optimize the lighting in IKEA Metod tall cabinets efficiently:
- LED strips vs. spotlights: LED strips work very well because they are flexible, easy to install, and provide even light distribution. Spotlights often create focused lighting, which can also be useful when targeted, for example, in the upper area.
- Placement: It is best to install LED strips vertically on the inner side walls of the cabinet. This way, the entire depth is well illuminated from top to bottom. Alternatively, narrow light bars can be mounted on the upper inner side to flood the area from above.
- Power supply: Wired solutions are more durable and provide consistent lighting but require careful cable management. Battery-powered LEDs are easier to install but need regular maintenance or replacement. For tall cabinets, which are usually placed in kitchens, I recommend a fixed power supply to ensure safety and convenience.
- Installation: Make sure to attach lights and cables with high-quality double-sided tape or screws (if possible without visible holes). IKEA Metod tall cabinets usually allow accessories to be attached to the side walls or via pre-formed edge profiles.
Finally, it is advisable to do a test setup before the final installation to check the light color (warm white or cool white) and brightness.
If you like, I can also provide some specific product suggestions.
Palenar
6 Sep 2024 11:15
Hello ridutar,
Regarding lighting for deep Ikea Metod tall cabinets, I have had very good experiences with the following solutions, which I would be happy to explain in detail:
- I strongly recommend using high-quality, dimmable LED strips with a color temperature of around 3000K (warm white). These provide pleasant lighting without harsh reflections.
- The ideal installation is vertical along the inner cabinet walls, with at least two LED strips per cabinet side to avoid shadows. Some users also place them on the inside of the doors if these are transparent or open.
- For power supply: the most professional option is LED systems hardwired via a power supply.
- During installation, pay attention to cable management: use cable clips on the back panel or hide cables on the sides to avoid any storage obstacles.
- A small tip: sensor controls (motion detectors or magnetic switches) significantly improve convenience by automatically turning on the lights when the door is opened.
- When sizing power cables and power supplies, consider the maximum load of the LEDs to prevent overheating or voltage drops.
- Also important: lighting elements should be moisture-resistant if the cabinets are near cooking areas or sinks.
In short: some planning in advance reduces later complications. If you like, I can create a shopping list and installation guide for you.
ridutar
7 Sep 2024 07:56
Jensson schrieb:
LED strips are very suitable because they are flexible, easy to install, and provide an even distribution of light.
Thank you very much for the helpful tips – the vertical placement on the side wall makes sense to me, especially for the even illumination.
Palenar schrieb:
Sensor controls (motion detectors or magnetic switches) make using the lights much more convenient, as the lighting turns on automatically when the door is opened.
The idea of sensors sounds very practical – do you have a recommendation that works well with IKEA Metod tall cabinets? I want to avoid installing technology that is too complicated, prone to failure, or difficult to connect.
Also: In some cases, I have considered mounting the lights on the inside of the door. Are there any experiences regarding the durability and protection of the lights with frequent opening and closing?
Maybe someone else has experience with these details?
Jensson
8 Sep 2024 10:03
ridutar schrieb:
The sensors sound very practical – do you have a recommendation that works well with IKEA Metod tall cabinets?
Sensors, especially magnetic switches for cabinet doors, are indeed very easy to install. Small reed switches are often used; they take up very little space and use a magnet to turn the LED control on and off. They are generally quite durable and cost-effective.
- I would avoid wireless or radio-controlled modules, as these usually require more complex control systems.
- Wired magnetic sensors can be simply attached next to the door frame without damaging the cabinet structure. The wiring can then run along a corner or behind the trim.
ridutar schrieb:
In some cases, I have also considered mounting the lights on the inside of the door. Are there any experiences regarding the stability and protection of the light with frequent opening and closing?
In general: as long as the lights are slim, securely fixed, and use flexible cables, they hold up without problems. Especially narrow LED strips are very robust. It is important that the cable routing remains flexible and avoids bends or pressure points. I recommend flexible flat cables and sturdy adhesive or clip fasteners.
If you have questions about the installation, I’m happy to help.
